I am very new to all this so I have gone through the documentation over and over and have combs through a ton of forum posts but it’s been 4 days now and I’m still at a loss.
Thought I would post in here and see if anyone has some insight for a Newbie - I can’t seem to figure out how to setup the Chirpstack Gateway Bridge
HW:Rpi 3B | Waveshare SX1302 Hat w/ SX1303 Module running ChripstackOS
Model** Raspberry Pi 3 Model B Rev 1.2
Architecture** ARMv7 Processor rev 4 (v7l)
Target Platform** bcm27xx/bcm2709
Firmware Version** ChirpStack Gateway OS 4.3.2 Full / LuCI openwrt-23.05 branch git-23.355.78874-80140aa
Kernel Version** 5.15.137
Says my Gateway is Online but when I get to the Chripstack-Gateway-Bridge Step, I can’t seem to find it in the CLI to even add/edit a config file
Does in need to be installed like the Raspberry Pi instructions say? If so,how? I get -ash: apt: not found
root@chirpstack-cf3477:~# uci show chirpstack-concentratord
chirpstack-concentratord.@global[0]=global
chirpstack-concentratord.@global[0].chipset=‘sx1302’
chirpstack-concentratord.@sx1301[0]=sx1301
chirpstack-concentratord.@sx1301[0].model=‘imst_ic880a’
chirpstack-concentratord.@sx1301[0].region=‘EU868’
chirpstack-concentratord.@sx1301[0].channel_plan=‘eu868’
chirpstack-concentratord.@sx1301[0].gateway_id=‘b827ebfffecf3477’
chirpstack-concentratord.@sx1301[0].antenna_gain=‘2’
chirpstack-concentratord.@sx1302[0]=sx1302
chirpstack-concentratord.@sx1302[0].model=‘waveshare_sx1302_lorawan_gateway_hat’
chirpstack-concentratord.@sx1302[0].region=‘US915’
chirpstack-concentratord.@sx1302[0].channel_plan=‘us915_0’
chirpstack-concentratord.@sx1302[0].gnss=‘1’
chirpstack-concentratord.@sx1302[0].antenna_gain=‘2’
chirpstack-concentratord.@2g4[0]=2g4
chirpstack-concentratord.@2g4[0].model=‘semtech_sx1280z3dsfgw1’
chirpstack-concentratord.@2g4[0].region=‘ISM2400’
chirpstack-concentratord.@2g4[0].channel_plan=‘ism2400’
chirpstack-concentratord.@2g4[0].antenna_gain=‘2’
root@chirpstack-cf3477:~# uci show chirpstack-mqtt-forwarder
chirpstack-mqtt-forwarder.@mqtt[0]=mqtt
chirpstack-mqtt-forwarder.@mqtt[0].topic_prefix=‘us915_0’
chirpstack-mqtt-forwarder.@mqtt[0].server=‘tcp://localhost:1883’
chirpstack-mqtt-forwarder.@mqtt[0].qos=‘0’
chirpstack-mqtt-forwarder.@filters[0]=filters
root@chirpstack-cf3477:~# uci show chirpstack-udp-forwarder
chirpstack-udp-forwarder.@server[0]=server
chirpstack.@network[0]=network
chirpstack.@network[0].net_id=‘000000’
chirpstack.@network[0].enabled_regions=‘us915_0’
Example of my current logread -f
Mon Feb 12 21:51:34 2024 user.info chirpstack-concentratord-sx1302[2140]: Publishing stats event, rx_received: 0, rx_received_ok: 0, tx_received: 0, tx_emitted: 0
Mon Feb 12 21:51:34 2024 user.info chirpstack-mqtt-forwarder[2609]: Received gateway stats
Mon Feb 12 21:51:34 2024 user.info chirpstack-mqtt-forwarder[2609]: Sending gateway stats event, topic: us915_0/gateway/0016c001f15d647c/event/stats
Mon Feb 12 21:52:04 2024 user.info chirpstack-concentratord-sx1302[2140]: Publishing stats event, rx_received: 0, rx_received_ok: 0, tx_received: 0, tx_emitted: 0
Mon Feb 12 21:52:04 2024 user.info chirpstack-mqtt-forwarder[2609]: Received gateway stats
Mon Feb 12 21:52:04 2024 user.info chirpstack-mqtt-forwarder[2609]: Sending gateway stats event, topic: us915_0/gateway/0016c001f15d647c/event/stats
