I’m running Chirpstack v4 and beside the data i was expecting also “device_frmpayload_data_location” in the post towards influxdb, should i add some config for this since maybe is not sent by default?
Could you share your decoded payload?
That is the location from the rxInfo elements. This is not directly related to the location of your device. E.g. the device and gateway might be kms apart.
The latitude and longitude need to be present in the object field. See also:
https://www.chirpstack.io/docs/chirpstack/integrations/influxdb.html#location-data
