playing with the installation_margin network server parameter i’m trying to set the maximum tx power value to a group of devices. Unfortunatly they don’t support TXPowerIndex 0 (i receive nack for it).
After the nack Chirpstack set MinSupportedTXPowerIndex to 1 but i’ve to wait a long time for the new adr request.
So, is it possibile to specify MinSupportedTXPowerIndex = 1 for these devices to have the ack at their first new adr request?
No, this is not possible. I believe this is actually more a “bug” at the device side. The (latest) Regional Parameter specification defines the TXPower table as values relative to the max. TX power supported by the device. Therefore 0 should always be a valid value.
Excuse me Brocaar, is it right saying that at the next adr request the network server will send TXPowerIndex 1 instead 0 if in the device session MinSupportedTXPowerIndex is now 1 after the Nack?
I’m worried of a stalled situation of tx_power requests?
Is it possibile to modify the wrong *SupportedTXPowerIndex values changing the session info from Redis?
(Note: ok you told me that txpower 0 is compliant with Lora defs, unfortunatly i’m not the developer of the sensor and i’ve no info about its implementation but i’ve to make it works :).
An ADR request does not change the state of the device-session, an ADR answer (ACK or nACK) does. In your case, the device sent a TX power nACK on 0, in which case ChirpStack assumes that value 0 is not supported, increasing the MinSupportedTXPowerIndex to 1.
This looks valid to me The next ADR req. will use a TX Power value of >= 1.
There is no API for this and I would avoid making manual modifications. In this case I would recommend to wait until the device “stabilizes”. The MinSupportedTXPowerIndex is exactly implemented for this reason (as is the MaxSupportedTXPowerIndex).
May invalidate the network server algorithm to calculate the next correct TxPowerIndex to transmit to the devices. Isn’t it?
Indeed for devices with these kind of values i cannot see any new adr request.
Another question: technically if there is an adr variation calculated by the network server this should be sent at the first available downlink window? Or are there some timers that delay adr requests to a specific device to avoid too frequent changes?
sorry for my huge number of questions. This is always related to adr request problem.
A device (always of the bugged model) had adr flag = true (as the others) in device session, after a nack for the request of TxPowerIndex = 0 the ADR flag became “false”.
Is it chirpstack network server that in some way has flagged it as not adr capable due to the nack?
And in that case, i could i reactivate the adr flag of the device?
