application/3101de9f-6ad1-4bdc-babc-e339439ce135/device/e66230c79f0c7d2a/command/down
the downlink doesnt recieve by device, but on portal
recieves well,
what should be mistake?
recieves well,
I’m not 100% sure what you mean with this. By showing a screenshot of an empty queue, you mean it was sent by ChirpStack but not received by the device?
Thanks for rapid reach,
i want to downlink in 2 ways with MQTT,
Unicast ( single device)
and Multicast
need to make MQTT with C# application
here is my code sample but somethings wrong, can you assist me to fix it?
using MQTTnet;
using MQTTnet.Client;
using MQTTnet.Client.Options;
using System.Text;
using System.Threading.Tasks;
public class Program
public static async Task Main(string[] args)
// MQTT client oluştur
var factory = new MqttFactory();
var mqttClient = factory.CreateMqttClient();
// MQTT client ayarları
var options = new MqttClientOptionsBuilder()
.WithClientId("YourClientId")
.WithTcpServer("YourMqttBrokerAddress", 1883) // Port numarası genellikle 1883'tür
.WithCredentials("YourUsername", "YourPassword")
.WithCleanSession()
.Build();
// MQTT client'ı bağla
await mqttClient.ConnectAsync(options);
// Downlink mesajını oluştur
var downlinkMessage = new
confirmed = true, // Onaylanmış downlink mesajı mı?
fPort = 1, // FPort değeri
data = "SGVsbG8gd29ybGQ=" // Base64 formatında veri ("Hello world" örneği)
// Downlink mesajını JSON'a çevir
var downlinkMessageJson = JsonConvert.SerializeObject(downlinkMessage);
// Downlink mesajını MQTT mesajına çevir
var message = new MqttApplicationMessageBuilder()
.WithTopic("application/{APPLICATION_ID}/device/{DEV_EUI}/command/down") // Uygulama ID'si ve cihaz EUI'si ile konuyu değiştirin
.WithPayload(downlinkMessageJson)
.WithExactlyOnceQoS()
.WithRetainFlag()
.Build();
// Downlink mesajını gönder
await mqttClient.PublishAsync(message);
Thanks
That’s totally true, i send from also hex data, its totally works fine but with mqtt application, it not got recieve from device, maybe i am missing some querry or url?
i didnt use deveui at payload json, problem may acquire becaause of that?
