Hoping someone can point me to something to try as I am out of ideas?
I am receiving the following error from docker logs chirpstack:
2024-08-11T17:05:20.211771Z ERROR chirpstack::integration::mqtt: MQTT error error=I/O: failed to lookup address information: Name does not resolve
A few points:
- .env file lives at level of docker-compose.yml. A docker inspect of chirpstack reveals that chirpstack indeed sees the environment variables as expected.
- With two ssh terminals I tested that the virtual port of 183 can subscribe and see messages from system port 1883 publishing.
- The same mechanism with postgresql works (see snippet below from chirpstack.toml) as I can log into my database and see the tables chirpstack has created.
- Finally all other logs are clean on redis, postgresql, mosquitto, HaSS, gateway.
Here is my setup:
docker-compose.yml
services:
chirpstack:
container_name: network_app_server
image: chirpstack/chirpstack:4
command: -c /etc/chirpstack
restart: unless-stopped
volumes:
depends_on:
- postgres
- mosquitto
- redis
environment:
- MQTT_BROKER_HOST=mosquitto
- REDIS_HOST=redis
env_file:
- .env
ports:
- 8080:8080
mosquitto:
container_name: broker
image: eclipse-mosquitto:2
ports:
- 1883:183 # chirpStack
volumes:
- ./configuration/mosquitto/config/:/mosquitto/config/
- ./containers/mosquitto/data:/mosquitto/data
- ./containers/mosquitto/log:/mosquitto/log
- ./containers/mosquitto/certs:/mosquitto/certs
env_file:
- .env
chirpstack.toml (location relative to docker yaml ./configuration/chirpstack/)
[integration]
enabled = ["mqtt", "postgresql"]
[integration.mqtt]
server = "tcp://${MQTT_BROKER_HOST}:183/"
json = true
[integration.postgresql]
dsn="postgres://$POSTGRES_USER:$POSTGRES_PASSWORD@$POSTGRESQL_HOST/$POSTGRES_DB?sslmode=disable"
mosquitto.conf (location relative to docker yaml ./configuration/mosquitto/config/)
listener 183
#password_file ../../../.env
allow_anonymous true
Thank you
Steve
