We are trying to connect a Tektelic Kona Micro Gateway and it proves to be a frustrating process. Here is what is at play here and the error message.
Gateway : Tektelic Kona Micro (up to date) /hereby named “device”
Chipstack-gateway-bridge : Installed and running on Device
Chirpstack Instance : Full install and functional on GCS VM
after installing the bridge and updating the config.json file and .toml file, we get an error message:
Mar 10 12:51:09 kona-micro monit[1910]: ‘chirpstack-gateway-bridge’ stop on user request
Mar 10 12:51:09 kona-micro monit[1910]: Monit daemon with PID 1910 awakened
Mar 10 12:51:09 kona-micro monit[1910]: Awakened by User defined signal 1
Mar 10 12:51:09 kona-micro monit[1910]: ‘chirpstack-gateway-bridge’ stop: ‘/bin/bash -c /etc/init.d/chirpstack-gateway-bridge stop’
Mar 10 12:51:09 kona-micro chirpstack-gateway-bridge[19871]: time=“2021-03-10T12:51:09Z” level=info msg=“signal received” signal=terminated
Mar 10 12:51:09 kona-micro chirpstack-gateway-bridge[19871]: time=“2021-03-10T12:51:09Z” level=warning msg=“shutting down server”
Mar 10 12:51:10 kona-micro monit[1910]: ‘chirpstack-gateway-bridge’ stop action done
Mar 10 12:51:14 kona-micro tek_mqtt_bridge[1888]: [DEBUG ] bridge_mqtt.c:81 MQTT initializing
Mar 10 12:51:17 kona-micro tek_mqtt_bridge[1888]: [ERROR ] bridge_mqtt.c:131 failed to connect with MQTT code: 4
Mar 10 12:51:17 kona-micro tek_mqtt_bridge[1888]: [ERROR ] main.c:795 cannot initialize MQTT
Mar 10 12:51:17 kona-micro tek_mqtt_bridge[1888]: [INFO ] main.c:783 initiating bridge restart
Mar 10 12:51:19 kona-micro monit[1910]: ‘chirpstack-gateway-bridge’ start on user request
Mar 10 12:51:19 kona-micro monit[1910]: Monit daemon with PID 1910 awakened
Mar 10 12:51:19 kona-micro monit[1910]: Awakened by User defined signal 1
Mar 10 12:51:19 kona-micro monit[1910]: ‘chirpstack-gateway-bridge’ start: ‘/bin/bash -c /etc/init.d/chirpstack-gateway-bridge start’
Mar 10 12:51:19 kona-micro monit[1910]: ‘chirpstack-gateway-bridge’ start action done
Mar 10 12:51:19 kona-micro chirpstack-gateway-bridge[23079]: time=“2021-03-10T12:51:19Z” level=info msg=“starting ChirpStack Gateway Bridge” docs=xxxxx://www.chirpstack.io/gateway-bridge/" version=3.10.0
Mar 10 12:51:19 kona-micro chirpstack-gateway-bridge[23079]: time=“2021-03-10T12:51:19Z” level=info msg=“backend/semtechudp: starting gateway udp listener” addr=“127.0.0.1:1700”
Mar 10 12:51:22 kona-micro chirpstack-gateway-bridge[23079]: time=“2021-03-10T12:51:22Z” level=info msg=“integration/mqtt: connected to mqtt broker”
Mar 10 12:51:22 kona-micro chirpstack-gateway-bridge[23079]: time=“2021-03-10T12:51:22Z” level=warning msg="[store] memorystore wiped" module=mqtt
Mar 10 12:51:37 kona-micro tek_mqtt_bridge[1888]: [DEBUG ] bridge_mqtt.c:81 MQTT initializing
Mar 10 12:51:40 kona-micro tek_mqtt_bridge[1888]: [ERROR ] bridge_mqtt.c:131 failed to connect with MQTT code: 4
Mar 10 12:51:40 kona-micro tek_mqtt_bridge[1888]: [ERROR ] main.c:795 cannot initialize MQTT
Mar 10 12:51:40 kona-micro tek_mqtt_bridge[1888]: [INFO ] main.c:783 initiating bridge restart
Mar 10 12:51:44 kona-micro chirpstack-gateway-bridge[23079]: time=“2021-03-10T12:51:44Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 stats_id=4c397712-6f17-4c69-a410-f5e5422d4f43 topic=/devices/gw-647fdafffe007db4/events/stats
Mar 10 12:51:57 kona-micro chirpstack-gateway-bridge[23079]: time=“2021-03-10T12:51:57Z” level=info msg=“integration/mqtt: subscribing to topic” qos=0 topic="/devices/gw-647fdafffe007db4/commands/#"
Mar 10 12:52:00 kona-micro tek_mqtt_bridge[1888]: [DEBUG ] bridge_mqtt.c:81 MQTT initializing
Mar 10 12:52:02 kona-micro tek_mqtt_bridge[1888]: [ERROR ] bridge_mqtt.c:131 failed to connect with MQTT code: 4
Mar 10 12:52:02 kona-micro tek_mqtt_bridge[1888]: [ERROR ] main.c:795 cannot initialize MQTT
Mar 10 12:52:02 kona-micro tek_mqtt_bridge[1888]: [INFO ] main.c:783 initiating bridge restart
root@kona-micro:/var/log#
Config.json file
“SX1301_array_conf”:[
“board_freq_band”: “US915”,
“SX1301_conf”:[
“chip_enable”: true,
“chan_multiSF_0”: {“chan_rx_freq”: 903900000, “spread_factor”: “7-10” },
“chan_multiSF_1”: {“chan_rx_freq”: 904100000, “spread_factor”: “7-10” },
“chan_multiSF_2”: {“chan_rx_freq”: 904300000, “spread_factor”: “7-10” },
“chan_multiSF_3”: {“chan_rx_freq”: 904300000, “spread_factor”: “7-10” },
“chan_multiSF_4”: {“chan_rx_freq”: 904700000, “spread_factor”: “7-10” },
“chan_multiSF_5”: {“chan_rx_freq”: 904900000, “spread_factor”: “7-10” },
“chan_multiSF_6”: {“chan_rx_freq”: 905100000, “spread_factor”: “7-10” },
“chan_multiSF_7”: {“chan_rx_freq”: 905300000, “spread_factor”: “7-10” },
“chan_LoRa_std” : {“chan_rx_freq”: 904600000, “bandwidth”: 500000, “spread_factor”: 8 },
“chan_FSK” : {“chan_rx_freq”: 904600000, “bandwidth”: 250000, “bit_rate”: 100000 }
“loramac_public”:true,
“aes_key”: “ABCDEF0123456789ABCDEF0123456789”
“gateway_conf”: {
“server_address”: “127.0.0.1”,
“serv_port_up”: 1700,
“serv_port_down”: 1700,
/* adjust the following parameters for your network /
“keepalive_interval”: 60,
“stat_interval”: 60,
“push_timeout_ms”: 100,
/ forward only valid packets */
“forward_crc_valid”: true,
“forward_crc_error”: false,
“forward_crc_disabled”: false
chirpstack-gateway-bridge.toml
This configuration provides a Semtech UDP packet-forwarder backend and
integrates with a MQTT broker. Many options and defaults have been omitted
for simplicity.
See https://www.chirpstack.io/gateway-bridge/install/config/ for a full
configuration example and documentation.
[general]
debug=5, info=4, warning=3, error=2, fatal=1, panic=0
log_level=5
Log to syslog.
When set to true, log messages are being written to syslog.
log_to_syslog=true
Gateway backend configuration.
[backend]
Backend type.
type=“semtech_udp”
Semtech UDP packet-forwarder backend.
[backend.semtech_udp]
ip:port to bind the UDP listener to
Example: 0.0.0.0:1700 to listen on port 1700 for all network interfaces.
This is the listener to which the packet-forwarder forwards its data
so make sure the ‘serv_port_up’ and ‘serv_port_down’ from your
packet-forwarder matches this port.
udp_bind = “127.0.0.1:1700”
Integration configuration.
[integration]
Payload marshaler.
This defines how the MQTT payloads are encoded. Valid options are:
* protobuf: Protobuf encoding (this will become the ChirpStack Gateway Bridge v3 default)
* json: JSON encoding (easier for debugging, but less compact than ‘protobuf’)
marshaler=“protobuf”
MQTT integration configuration.
[integration.mqtt]
Event topic template.
event_topic_template=“gateway/{{ .GatewayID }}/event/{{ .EventType }}”
Command topic template.
command_topic_template=“gateway/{{ .GatewayID }}/command/#”
MQTT authentication.
[integration.mqtt.auth]
type=“gcp_cloud_iot_core”
[integration.mqtt.auth.gcp_cloud_iot_core]
server=“ssl://mqtt.googleapis.com:443”
device_id=“gw-647FDAFFFE007DB4”
project_id=“thingsfactorychirpstack”
cloud_region=“us-central1”
registry_id=“tf-gateways-registry”
jwt_key_file="/etc/chirpstack-gateway-bridge/rsa_private.pem"
#Edited by F Page - March 2021
any help would be appreciated.
Thanks
