I have 4 devices conected on a gateway.
They are comunicating with my Chirpstark , but the MQTT integrations don’t send all events.
One device is set to send information every 5 minutes, the chirpstack receive the UP event, but he don’t send all mensages through MQTT, something like every 4 or 5 events.
I need to get all events through MQTT
I’m using the MQTT integration.
My chirpstack.toml file :
[integration]
enabled=[“mqtt”]
MQTT integration configuration.
[integration.mqtt]
# Event topic template.
event_topic="application/{{application_id}}/device/{{dev_eui}}/event/{{event}}"
# Command topic.
# This is the topic on which the MQTT subscribes for receiving (enqueue) commands.
command_topic="application/{{application_id}}/device/{{dev_eui}}/command/{{command}}"
# Use JSON encoding instead of Protobuf (binary).
json=true
server="tcp://{MY-SERVER}:1883"
username="test"
password="123"
# Quality of service level
# 0: at most once
# 1: at least once
# 2: exactly once
qos=0
# Clean session
clean_session=false
# Client ID
# broker. A client id must be no longer than 23 characters. If left blank,
# a random id will be generated by ChirpStack.
client_id=""
ca_cert=""
tls_cert=""
# TLS key file (optional)
tls_key=""
