Im trying to add MQTT integration to the application, I managed to generate the certs file and I add the following to the chirpstack-application-server.toml file:
[application_server.integration.mqtt.client]
ca_cert=“certs/ca/ca.pem”
ca_key=“certs/ca/ca-key.pem”
when I press generate certificate, I got (open certs/ca/ca.pem: no such file or directory (code: 2))
can anyone please explain where should I add the certs file?
@Ibrahim_Omari ,I have the same problem. Can you give me some explication please?how did you do it? what is the exact path of the certs file? and is it on chirpstack-docker or in a separate file ?
