MQTT with self-signed certificates
Hi!
I am trying to connect lora components to MQTT broker (VerneMQ) with self-signed certificates.
I can connect to the broker with CA file with MQTT.fx without any problems, but when I add to the config
ca_cert="/etc/lora-app-server/mqtt_ca.crt"
I get openssl errors (server="ssl://127.0.0.1:8883"):
ERRO[0000] handler/mqtt: connecting to broker error, will retry in 2s: Network Error : x509: cannot validate certificate for 127.0.0.1 because it doesn't contain any IP SANs
or (server="ssl://localhost:8883")
ERRO[0000] handler/mqtt: connecting to broker error, will retry in 2s: Network Error : x509: certificate is valid for vernemq, not localhost
Broker logs for this are (no messages for mqtt.fx connection):
2018-11-22 08:34:04.890 [info] <0.546.0> TLS server: In state certify received CLIENT ALERT: Fatal - Bad Certificate
What is the best way to solve this problem?
I think that’s the key: you created a certificate for the host vernemq, which of course isn’t equal to localhost and thus is invalid. Create one for localhost and you should be fine.
Thing is I did not set up hostnames. Any other way to solve this without messing with certificates regeneration?
If your host isn’t named as the certificate says, it should throw an error or else that’d be a security hole. So no, the certificate must be correct.
