Please note that the MQTT certificates are optional. If you have configured your MQTT broker (e.g. Mosquitto) to validate the client-certificates then these are needed, in any other case you can just connect as you normally would to your MQTT broker.
But how can I do that?
When I try to set up the MQTT connection, instead of the “+” like with the other integrations, I only see “Get certificate”.
(And when I click that I get the “Generate certificate” button that leads to the error message mentioned in the thread above.)
The [integration.mqtt] configuration configures the ChirpStack MQTT Integration, this can be a different MQTT broker than the MQTT broker used for the gateway communication. You will find the gateway MQTT configuration in the region_XXXXX.toml files (e.g. region_eu868.toml).
