Good afternoon, I would like some help in configuring the gateway. I am running on Windows Docker, the gateway itself is MTCAP3-EN-A23EEA-DEM
Firmware 6.3.2 Multitech - ChirpStack open-source LoRaWAN® Network Server documentation I did everything according to this instruction
a@mtcap3:/tmp$ sudo opkg install chirpstack-gateway-bridge_4.0.10-r1_arm926ejste.ipk
Password:
Collected errors:
Solver encountered 1 problem(s):
Problem 1/1:
package chirpstack-gateway-bridge-4.0.10-r1.arm926ejste does not have a compatible architecture
Solution 1:
do not ask to install chirpstack-gateway-bridge-4.0.10-r1.arm926ejste
I get this data via ssh, but the admin panel does not see the gateway:
2024-04-15T14:00:38.425276+00:00 mtcap3 chirpstack-mqtt-forwarder[1895]: PULL_DATA received, random_token: 33955, remote: 127.0.0.1:43492
