Multiple frequency setup
for a specific use case of some gateways we have different gateways with different frequencies. With geolocation we switch the right version of the packet forwarder and load the right frequency with its gateway. What would be the right setup in the Chirpstack configuration using Docker compose. Can a networkserver handle multiple frequencies? Also the application cannot add different network servers of a already added hostname, even if the port is different.
Does somebody have a detailed solution.
kind regards
For multiple regions / channel-plan support, please see: https://forum.chirpstack.io/search?q=multiple%20region.
