Hi
I have an application where the LoraServer is installed locally on a PC, while Gatways can be either local, i.e. on the same LAN as the PC, or connected through Cellular network (4G).
For the cellular Gateway I need the broker to be in the cloud (given that local broker do not have public and static IP) while for the local gateways I would want them to use a local broker (that do not depend on internet-connection).
Is there a way to configure two MQTT brokers in network server? If not, what other solution is there?
Thanks
Nathan
