Hello everybody.
I have Multitech Gateway with a MTAC-LORA-H-868 Accessory Card. The thing was runnig good. after a power impact (gateway was donw) and starting again, i have the following issue:
the packet forwarder fails to start with the following errors:
ERROR: FAIL TO CONNECT BOARD
<-- snip -->
ERROR: [main] failed to start the concentrator
Anyone has an idea what this is and can help me with this?
thanks and regards,
you can find the full log here:
gw_board_setconf:427: Note: board configuration; lorawan_public:1, clksrc:0
lgw_rxrf_setconf:476: WARNING: NOT A VALID TX NOTCH FILTER FREQUENCY [126000…250000]Hz
lgw_rxrf_setconf:488: Note: rf_chain 0 configuration; en:1 freq:867500000 rssi_offset:-162.000000 radio_type:2 tx_enable:1 tx_notch_freq:0
lgw_rxrf_setconf:488: Note: rf_chain 1 configuration; en:1 freq:868500000 rssi_offset:-162.000000 radio_type:2 tx_enable:0 tx_notch_freq:0
lgw_rxif_setconf:607: Note: LoRa ‘multi’ if_chain 0 configuration; en:1 freq:-400000 SF_mask:0x7e
lgw_rxif_setconf:607: Note: LoRa ‘multi’ if_chain 1 configuration; en:1 freq:-200000 SF_mask:0x7e
lgw_rxif_setconf:607: Note: LoRa ‘multi’ if_chain 2 configuration; en:1 freq:0 SF_mask:0x7e
lgw_rxif_setconf:607: Note: LoRa ‘multi’ if_chain 3 configuration; en:1 freq:-400000 SF_mask:0x7e
lgw_rxif_setconf:607: Note: LoRa ‘multi’ if_chain 4 configuration; en:1 freq:-200000 SF_mask:0x7e
lgw_rxif_setconf:607: Note: LoRa ‘multi’ if_chain 5 configuration; en:1 freq:0 SF_mask:0x7e
lgw_rxif_setconf:607: Note: LoRa ‘multi’ if_chain 6 configuration; en:1 freq:200000 SF_mask:0x7e
lgw_rxif_setconf:607: Note: LoRa ‘multi’ if_chain 7 configuration; en:1 freq:400000 SF_mask:0x7e
lgw_rxif_setconf:581: Note: LoRa ‘std’ if_chain 8 configuration; en:1 freq:-200000 bw:2 dr:2
lgw_rxif_setconf:637: Note: FSK if_chain 9 configuration; en:1 freq:300000 bw:3 dr:50000 (50000 real dr) sync:0xC194C1
*** Beacon Packet Forwarder for Lora Gateway ***
Version: 4.0.1
*** Lora concentrator HAL library version info ***
Version: 5.0.1;
INFO: Little endian host
INFO: found global configuration file global_conf.json, parsing it
INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
INFO: lorawan_public 1, clksrc 0
INFO: LBT is disabled
INFO: antenna_gain 0 dBi
INFO: Configuring TX LUT with 16 indexes
INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -162.000000, tx enabled 1, tx_notch_freq 0
INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -162.000000, tx enabled 0, tx_notch_freq 0
INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to 00800000A0002460
INFO: server hostname or IP address is configured to “10.10.10.12”
INFO: upstream port is configured to “1700”
INFO: downstream port is configured to “1700”
INFO: downstream keep-alive interval is configured to 10 seconds
INFO: statistics display interval is configured to 30 seconds
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: packets received with a valid CRC will be forwarded
INFO: packets received with a CRC error will be forwarded
INFO: packets received with no CRC will NOT be forwarded
INFO: Auto-quit after 60 non-acknowledged PULL_DATA
