Dear all, I have a little question. From where is taken the value or configuration of the “Region ID” field in the configuration of Gateway (GW)? I mean, I have a Mulittech GW configured (I think correctly) in us915 plan frequency as PACKET_FORWARDER but always I see this value and the “Region common-name” in EU868.
I have installed V4 of ChirpStack.
Thanks in advance.
The Region ID is based on the MQTT topic prefix, e.g. AU915 (channels 0 - 7) gateways would publish to au915_0/gateway/...., EU868 gateways to eu868/gateway/......
Hi @brocaar. Thak you very much for the response. Just as a comment, we need to set up this prefixes at the gateway and in the ChirpStack also, I mean in the “chirp-stack-bridge.toml” config files.
Regards.
I hope you are doing well. I will soon start using the MultiTech Gateway, specifically the MTCAP3-EN. I would like to know the different configurations you have made in the gateway to allow it to transmit data? Because I see that there is talk about the ChirpStack Gateway Bridge on one side and the ChirpStack MQTT Forwarder on the other.
Thank you in advance.
