Hi there!
I have set up a Gateway from Multitech with a Gateway-Bridge and Package-Forwarder and erverything is working fine.
The Packages are created by and send correct and arrive on the server.
I used the default package forwarder from semtech and the gateway-bridge from broccar.
(I’ll include the .init and conf files at the end)
However we noticed, GPS-Data is missing. If i do
sudo tcpdump -AUq -i lo port 1700
I get all the other Information in the stats file, but nothing about the gps data.
However
grep '' /dev/ttyXRUSB2
Shows, that the gateway knows, where it is.
After reading some topics, I included
“gps”:“true”,
and
“gps_tty_path”:"/dev/ttyXRUSB2"
in the global_conf.
Also i found a path ($gps_path) in the .init file of the package forwarder and changed it to /dev/XRUSB2.
I also tried to start the forwarder manually since it would give me more output to work with, but I always get the error no conf files found.
Somehow there is also no log data at /var/log/lora-pkt-fwd-1.log (where I would expect it).
However there is still no GPS data in the forwarder packages, has any of you guys an idea why?
Any help is really appreciated, I don’t know what to do further to fix this problem.
UPDATE:
I tried to use the fake gps Option to check if it works with it but when I edit the global_conf like
"fake_gps":"true",
"ref_latitude": xxxx,xx,
"ref_longitude": xxxx,xx,
"ref_altitude": xxx
Now the dump data shows correct lati and alti attitudes. (if i don’t set “gps”:“true”)
Has anybody experienced something similar to this?
How can I get the real data in?
CODE:
Packet-Forwarder : init
#!/bin/bash
NAME="lora-packet-forwarder"
ENABLED="yes"
[ -f /etc/default/$NAME ] && source /etc/default/$NAME
run_dir=/var/run/lora
opt_conf_dir=/opt/lora
conf_dir=/var/config/lora
conf_file=$conf_dir/global_conf.json
conf_file_local=$conf_dir/local_conf.json
pkt_fwd=$run_dir/1/lora_pkt_fwd
pkt_fwd_log=/var/log/lora-pkt-fwd-1.log
pkt_fwd_pidfile=$run_dir/lora-pkt-fwd-1.pid
port1=/sys/devices/platform/mts-io/ap1
port2=/sys/devices/platform/mts-io/ap2
lora_mtac_id="MTAC-LORA"
lora_1_0_hw="MTAC-LORA-1.0"
lora_1_5_h_hw="MTAC-LORA-1.5"
lora_2_1_hw="MTAC-LORA-2.1"
lora_mtac_id915="MTAC-LORA-915"
lora_mtac_id868="MTAC-LORA-868"
lora_mtac_h_id915="MTAC-LORA-H-915"
lora_mtac_h_id868="MTAC-LORA-H-868"
lora_mtcap_id="MTCAP-LORA"
lora_mtcap_id868="MTCAP-LORA-868"
lora_mtcap_id915="MTCAP-LORA-915"
lora_mtac_g_id="MTAC-LORA-G"
lora_mtac_g16_id868="MTAC-LORA-G16-868"
lora_mtac_g16_id915="MTAC-LORA-G16-915"
lora_mtac_g64_id868="MTAC-LORA-G64-868"
lora_mtac_g64_id915="MTAC-LORA-G64-915"
pkt_fwd_options=""
gps_path="/dev/ttyXRUSB2"
read_lora_hw_info() {
lora_id=$(mts-io-sysfs show lora/product-id 2> /dev/null)
lora_hw=$(mts-io-sysfs show lora/hw-version 2> /dev/null)
lora_eui=$(mts-io-sysfs show lora/eui 2> /dev/null)
lora_eui_raw=${lora_eui//:/}
hardware_found() {
if [[ "$lora_id" =~ "$lora_mtac_g_id" ]]; then
setup_mtcdt_2_1
elif [[ "$lora_id" =~ "$lora_mtcap_id" ]]; then
setup_mtcap
elif [[ "$lora_id" =~ "$lora_mtac_id" ]]; then
setup_mtcdt
else
return 1
fi
return 0
setup_mtcdt() {
if [ -d $port1 ] && [[ $(cat $port1/hw-version) = $lora_hw ]]; then
ln -sf /dev/spidev32766.2 /dev/spidev0.0
elif [ -d $port2 ] && [[ $(cat $port2/hw-version) = $lora_hw ]]; then
ln -sf /dev/spidev32765.2 /dev/spidev0.0
fi
if [ "$lora_hw" = "$lora_1_0_hw" ] && [[ ! "$lora_id" =~ .*-SPI ]]; then
if [ "$lora_id" = "$lora_mtac_id868" ]; then
GLOBAL_CONF=/opt/lora/global_conf.json.MTCDT_LORA_1_0.EU868
elif [ "$lora_id" = "$lora_mtac_id915" ]; then
GLOBAL_CONF=/opt/lora/global_conf.json.MTCDT_LORA_1_0.US915
else
echo "No valid configuration found for mtcdt exiting."
exit 1
fi
ln -sf /opt/lora/basic_pkt_fwd-usb $pkt_fwd
else
if [ "$lora_id" = "$lora_mtac_h_id868" ]; then
GLOBAL_CONF=/opt/lora/global_conf.json.MTCDT_LORA_1_5.EU868
elif [ "$lora_id" = "$lora_mtac_h_id915" ]; then
GLOBAL_CONF=/opt/lora/global_conf.json.MTCDT_LORA_1_5.US915
else
exit 1
fi
ln -sf /opt/lora/lora_pkt_fwd $pkt_fwd
fi
opt_conf_file=$opt_conf_dir/global_conf.json
opt_conf_file_local=$opt_conf_dir/local_conf.json
cp $GLOBAL_CONF $opt_conf_file
if ! [ -f $conf_file ]; then
mkdir -p /var/config/lora/
cp $opt_conf_file $conf_file
cp $opt_conf_file_local $conf_file_local
fi
setup_mtcap() {
if [ "$lora_id" = "$lora_mtcap_id868" ]; then
GLOBAL_CONF=/opt/lora/global_conf.json.MTCAP_LORA_1_5.EU868
elif [ "$lora_id" = "$lora_mtcap_id915" ]; then
GLOBAL_CONF=/opt/lora/global_conf.json.MTCAP_LORA_1_5.US915
else
echo "No valid configuration found for mtcap exiting."
exit 1
fi
fi
setup_mtcdt_2_1() {
if [[ "$lora_id" = "$lora_mtac_g16_id868" ]]; then
GLOBAL_CONF=/opt/lora/global_conf.json.MTAC_LORA_2_1_loc_single_antenna_16ch_EU868
elif [[ "$lora_id" = "$lora_mtac_g16_id915" ]]; then
GLOBAL_CONF=/opt/lora/global_conf.json.MTAC_LORA_2_1_loc_single_antenna_16ch_US915
elif [[ "$lora_id" = "$lora_mtac_g64_id868" ]]; then
GLOBAL_CONF=/opt/lora/global_conf.json.MTAC_LORA_2_1_test_single_antenna_64ch_8x8_EU868
elif [[ "$lora_id" = "$lora_mtac_g64_id915" ]]; then
GLOBAL_CONF=/opt/lora/global_conf.json.MTAC_LORA_2_1_loc_single_antenna_64ch_US915
else
return 1
fi
fi
ln -sf /opt/lora/pkt_forwarder $pkt_fwd
if [ -f $gps_path ]; then
pkt_fwd_options=" -g"
fi
do_start() {
mkdir -p $run_dir/1
rm -rf $run_dir/1/*
read_lora_hw_info
if hardware_found; then
echo "Found $lora_id with $lora_hw hardware. Configuring"
else
echo "$0: LORA card not detected"
exit 1
fi
echo "$0: $conf_file missing"
exit 1
fi
# copy conf files to the run directory
cp $conf_file $run_dir/1/
if [ -f $conf_file_local ]; then
cp $conf_file_local $run_dir/1/
sed -i.bak "s/\(.gateway_ID\"\s\:\s*\"\)<.>[^\"]\(.*\)/\1${lora_eui_raw}\2/g" /var/run/lora/1/local_conf.json
fi
sed -i.bak "s/\(.gateway_ID\"\s\:\s*\"\)<.>[^\"]\(.*\)/\1${lora_eui_raw}\2/g" /var/run/lora/1/global_conf.json
# start packet forwarder
echo -n "Starting $NAME: "
/usr/sbin/start-stop-daemon --chdir $run_dir/1 --background --start --make-pidfile \
--pidfile $pkt_fwd_pidfile --startas /bin/bash -- -c "exec $pkt_fwd $pkt_fwd_options"
renice -n -20 -p $(pgrep $(basename $pkt_fwd))
echo "OK"
do_stop() {
echo -n "Stopping $NAME: "
start-stop-daemon --stop --quiet --oknodo --pidfile $pkt_fwd_pidfile --retry 5
rm -f $pkt_fwd_pidfile
echo "OK"
if [ "$ENABLED" != "yes" ]; then
echo "$NAME: disabled in /etc/default"
exit
fi
case "$1" in
"start")
do_start
"stop")
do_stop
"restart")
## Stop the service and regardless of whether it was
## running or not, start it again.
do_stop
do_start
## If no parameters are given, print which are avaiable.
echo "Usage: $0 {start|stop|restart}"
exit 1
esac
local conf
"gateway_conf": {
"server_address": "localhost",
"serv_port_up": 1680,
"serv_port_down": 1680,
global conf
"SX1301_conf": {
"antenna_gain": 0,
"chan_FSK": {
"bandwidth": 125000,
"datarate": 50000,
"enable": true,
"if": 300000,
"radio": 1
"chan_Lora_std": {
"bandwidth": 250000,
"enable": true,
"if": -200000,
"radio": 1,
"spread_factor": 7
"chan_multiSF_0": {
"enable": true,
"if": -400000,
"radio": 1
"chan_multiSF_1": {
"datarate": 50000,
"enable": true,
"if": 300000,
"radio": 1
"chan_Lora_std": {
"enable": true,
"if": -200000,
"radio": 1,
"spread_factor": 7
"chan_multiSF_0": {
"enable": true,
"if": -400000,
"radio": 1
"chan_multiSF_1": {
"enable": true,
"if": -200000,
"radio": 1
"chan_multiSF_2": {
"enable": true,
"if": 0,
"radio": 1
"chan_multiSF_3": {
"enable": true,
"if": -400000,
"radio": 0
"chan_multiSF_4": {
"enable": true,
"if": -200000,
"radio": 0
"chan_multiSF_5": {
"enable": true,
"if": 0,
"radio": 0
"chan_multiSF_6": {
"enable": true,
"if": 200000,
"gateway_conf": {
"forward_crc_disabled": false,
"forward_crc_error": true,
"forward_crc_valid": true,
"gateway_ID": "<WILL-BE-AUTO-REPLACED-WITH-LORA-EUI>",
"keepalive_interval": 10,
"push_timeout_ms": 100,
"serv_port_down": 20000,
"serv_port_up": 20000,
"server_address": "52.3.215.147",
"stat_interval": 30,
"autoquit_threshold": 60,
"gps":"true",
"gps_tty_path":"/dev/ttyXRUSB2"
