HI Team,
I am using Multitech MTCDT-247A Gateway using Packet Forwarding option and I have installed lora-gateway-bridge in Multitech gateway. Updated MY cloud server IP in lora-gateway-bridge config file in Multitech gateway.
Google Cloud i have launched server Ubuntu 18.04 LTS & 16.04 Version. I have installed Loraserver & Lora-app-server.
am using Lora-app-server 3.3.1 & Loraserver 3.2.1 & lora-gateway-bridge 3.3.1 version in cloud server.
I have Created Network Servers,Gateway,Service,Device,Gateway,Application profile successfully.
I have added My Multitech gateway in gateway profile with out any issue.
I got error in logs creating Device/activating/reactivating device. Please find the below error.
unary call with code NotFound" error=“rpc error: code = NotFound desc = object does not exist” grpc.code=NotFound grpc.method=GetActivation grpc.service=api.DeviceService grpc.start_time=“2019-10-04T06:43:55Z” grpc.time_ms=4.474 peer.address=“127.0.0.1:58600” span.kind=server system=grpc
client unary call" error=“rpc error: code = NotFound desc = object does not exist” grpc.code=NotFound grpc.method=DeactivateDevice grpc.service=ns.NetworkServerService grpc.time_ms=0.986 span.kind=client system=grpc
Loraserver log everytime this only:-
Oct 04 08:55:29 mosquitto-2 loraserver[1431]: time=“2019-10-04T08:55:29Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" name=“gw:00800000a000474d”
Oct 04 08:55:49 mosquitto-2 loraserver[1431]: time=“2019-10-04T08:55:49Z” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=00800000a000474d
Oct 04 08:55:49 mosquitto-2 loraserver[1431]: time=“2019-10-04T08:55:49Z” level=info msg=“gateway updated” gateway_id=00800000a000474d
Oct 04 08:55:49 mosquitto-2 loraserver[1431]: time=“2019-10-04T08:55:49Z” level=info msg=“gateway/mqtt: publishing gateway command” command=config gateway_id=00800000a000474d qos=0 topic=gateway/00800000a000474d/command/config
Oct 04 08:55:49 mosquitto-2 loraserver[1431]: time=“2019-10-04T08:55:49Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" name=“gw:00800000a000474d”
Please any one idea please give me a solution.
Thanks
Panneer Selvam.G
