Hi, i Recently “Took over”
2 - MultiTech Macro Conduit V2.1. and 2 Multitech Pico MTCAP moving from Actility to Chirpstack.
These where flashed with mLinux 6.3 commissioning firmware.
MTCAP works fine but the Macro does not and i’m a bit lost.
Trying to start the packet forwarder on the Macro’s results in:
+++ Start of packet forwarder for ‘SX1301 array’ concentrator +++
Version string: 5.1.0-r4
SX1301 array library version string: 5.1.0
ERROR: opening SPI failed, returned -1
and doing ls -l /dev/sp* clearly shows nothing unlike on the mtcap.
I also tried the forwarder usb pkg but that also resulted in:
ERROR: FAIL TO CONNECT BOARD
ERROR: [main] failed to start the concentrator
As these are in i high tower quite far away i have not seen the hardware and not yet received the full specs.
Do you guys have any idea on how i would communicate ? Or how i can find out what concentrator i have as it seems not to be sx1301 in these…
