I have a Multitech Conduit IP67 Gateway. I followed the instructions an everything seems to be wirking fine, but my Gateway wont show up in loraserver.
INFO[0000] starting LoRa Gateway Bridge docs="https://www.loraserver.io/lora-gateway-bridge/" version=3.0.1
INFO[0000] backend/semtechudp: starting gateway udp listener addr="0.0.0.0:1700"
INFO[0000] integration/mqtt: connected to mqtt broker
INFO[0006] integration/mqtt: subscribing to topic qos=0 topic="gateway/00800000a0001f46/command/#"
INFO[0017] integration/mqtt: publishing event event=stats qos=0 topic=gateway/00800000a0001f46/event/stats
INFO[0047] integration/mqtt: publishing event event=stats qos=0 topic=gateway/00800000a0001f46/event/stats
INFO[0061] integration/mqtt: publishing event event=up qos=0 topic=gateway/00800000a0001f46/event/up
INFO[0077] integration/mqtt: publishing event event=stats qos=0 topic=gateway/00800000a0001f46/event/stats
INFO[0107] integration/mqtt: publishing event event=stats qos=0 topic=gateway/00800000a0001f46/event/stats
when i subscribe to the loraserver mqtt broker i can see that the messages are not in a correct format:
��F㊢� ��"��I@%X���@`h@ (J10.239.0.91
My Dragino and Raspberry Gateways ar working fine.
Any Ideas?
Thank you.
