i just handle downstream message from gateway but problem is, downlink message keeps wait while the message recieve from node
how can i change it to Class-C my nodes?
and on loraserver how can manage it?
thanks
thanks
LMiC is designed for Class-A and Class-B. There is no simple fix to make it Class-C compliant as well or it would have been updated already to included that.
There is should someone using lmic or some code for Arduino based node using Class C?
Control cu rent systems, nodes must be instantly receive messages
You could try the new arduino mkr-wan: https://store.arduino.cc/mkr-wan-1300
Seems that it support Class C (not sure about this. Just checked the source code)
Ttgo heltec module supports too but lmic not support guess need help on software
