I’ve been attempting to test out the mydevices integration on the new 3.0.8-test.1.
First I’d like to know what steps I need to take on the mydevices side to enable the integration. For instance several Lorawan networks are listed under the Lora tab on mydevice.com when you create a device but I don’t see Chirpstack as an option.
If I use the api to add the integration to an existing application I can do so and I pass it the following endpoint url:
https://lora.mydevices.com/v1/networks/loraserverio/uplink
As uplinks come in I can see the following in the log:
Feb 01 15:53:37 server chirpstack-application-server[13697]: time=“2020-02-01T15:53:37-05:00” level=info msg=“integration/mydevices: publishing event” ctx_id=a2b0f295-7635-4d8d-ae1b-346ed56f6c2e dev_eui=8daf60672de6eac2 endpoint=“https://lora.mydevices.com/v1/networks/loraserverio/uplink” event=up
I don’t see any errors but how can I get myDevices to actually watch for data from my deveui and populate it in my dashboard? With other networks you specify at least the deveui on mydevices.com after choosing the appropriate network from the Lora menu item.
