Need help with devonce error in dataframe
hi all,
i have a node working fine for years. Out of a sudden, about 5 days ago, it stopped transmitting data. I get a join request and a join accepted 2-3 times a day, but the device data stuck with a “validate dev-nonce error”.
What i did so far (like decribed in some posts the last few years) :
a) using the “clear devonce” button on the activation ui
b) deleted the activation messages in the data base by hand
Result: none, nothing changed
As the device is a TEK766 Level Sensor i can not reset it.
Any suggestions?
regards
Detlef
Try to disable framecounter validation and clear devNonce.
framecounter already disabled for a long time
Maybe it could be caused by a protocol version miss match?
The behavior of the devOnce is slightly different between 1.0.x versions, you could try to manually debug the devOnce (getting the PhyPayload) and see if it’s the expected behavior on the specified protocol
you are talking in riddles, the device is running on 1.03 and worked for years. How to debug te devnonce? I did not change the payload decode
checked the phypayload and it looks fine, reflecting the join request, any mor ideas?
