In an attempt to install Network server and App Server on two separate machines (NS on Raspberry Pi and AS on a VM/server), it seems that the NS is failing at some type of connection to the AS, although I was able to add the NS to the AS.
Here is the error log I am seeing on the NS side:
Dec 17 19:13:34 rak-gateway chirpstack-network-server[12707]: time="2019-12-17T19:13:34-05:00" level=warning msg="creating insecure application-server client" server="localhost:8001" Dec 17 19:13:34 rak-gateway chirpstack-network-server[12707]: time="2019-12-17T19:13:34-05:00" level=warning msg="grpc: addrConn.createTransport failed to connect to {localhost:8001 0 <nil>}. Err :connection error: desc = \"transport: Error while dialing dial tcp [::1]:8001: connect: connection refused\". Reconnecting..." Dec 17 19:13:34 rak-gateway chirpstack-network-server[12707]: time="2019-12-17T19:13:34-05:00" level=error msg="gateway: handle gateway stats error" ctx_id=9dc441f2-e103-4484-8cec-ab2f3855a2be error="get application-server client error: get application-server client error: create application-server api client error: dial application-server api error: context deadline exceeded"
I don’t see any errors from AS log. Any idea what I might have set up wrong? I think it has to do with the bind ip’s but I am not sure exactly which parameter. My config files for both AS and NS are below:
NS:
# This configuration configures ChirpStack Network Server for the EU868 band using a MQTT
# broker to communicate with the gateways. Many options and defaults have been
# omitted for simplicity.
# For other bands, see the ./examples/ sub-directory.
# See https://www.chirpstack.io/network-server/install/config/ for a full
# configuration example and documentation.
# PostgreSQL settings.
# Please note that PostgreSQL 9.5+ is required.
[postgresql]
# PostgreSQL dsn (e.g.: postgres://user:password@hostname/database?sslmode=disable).
# Besides using an URL (e.g. 'postgres://user:password@hostname/database?sslmode=disable')
# it is also possible to use the following format:
# 'user=chirpstack_ns dbname=chirpstack_ns sslmode=disable'.
# The following connection parameters are supported:
# * dbname - The name of the database to connect to
# * user - The user to sign in as
# * password - The user's password
# * host - The host to connect to. Values that start with / are for unix domain sockets. (default is localhost)
# * port - The port to bind to. (default is 5432)
# * sslmode - Whether or not to use SSL (default is require, this is not the default for libpq)
# * fallback_application_name - An application_name to fall back to if one isn't provided.
# * connect_timeout - Maximum wait for connection, in seconds. Zero or not specified means wait indefinitely.
# * sslcert - Cert file location. The file must contain PEM encoded data.
# * sslkey - Key file location. The file must contain PEM encoded data.
# * sslrootcert - The location of the root certificate file. The file must contain PEM encoded data.
# Valid values for sslmode are:
# * disable - No SSL
dsn="postgres://chirpstack_ns:dbpassword@localhost/chirpstack_ns?sslmode=disable"
# Redis settings
# Please note that Redis 2.6.0+ is required.
[redis]
# Redis url (e.g. redis://user:password@hostname/0)
# For more information about the Redis URL format, see:
# https://www.iana.org/assignments/uri-schemes/prov/redis
url="redis://localhost:6379"
# Network-server settings.
[network_server]
# Network identifier (NetID, 3 bytes) encoded as HEX (e.g. 010203)
net_id="000000"
# LoRaWAN regional band configuration.
# Note that you might want to consult the LoRaWAN Regional Parameters
# specification for valid values that apply to your region.
# See: https://www.lora-alliance.org/lorawan-for-developers
[network_server.band]
name="US_902_928"
# LoRaWAN network related settings.
enabled_uplink_channels=[8,9,10,11,12,13,14,15]
# Disable ADR
# When set, this globally disables ADR.
disable_adr=true
# Extra channel configuration.
# Use this for LoRaWAN regions where it is possible to extend the by default
# available channels with additional channels (e.g. the EU band).
# The first 5 channels will be configured as part of the OTAA join-response
# (using the CFList field).
# The other channels (or channel / data-rate changes) will be (re)configured
# using the NewChannelReq mac-command.
# [[network_server.network_settings.extra_channels]]
# frequency=867100000
# min_dr=0
# max_dr=5
# frequency=867300000
# min_dr=0
# max_dr=5
# frequency=867500000
# min_dr=0
# max_dr=5
# frequency=867700000
# min_dr=0
# max_dr=5
# frequency=867900000
# min_dr=0
# max_dr=5
# Class B settings
[network_server.network_settings.class_b]
# Ping-slot data-rate.
ping_slot_dr=0
# Ping-slot frequency (Hz)
# Set this to 0 to use the default frequency plan for the configured region
ping_slot_frequency=0
# Network-server API
# This is the network-server API that is used by ChirpStack Application Server or other
# custom components interacting with ChirpStack Network Server.
[network_server.api]
bind="0.0.0.0:8000"
#bind="raspi_ip:8000"
# Backend defines the gateway backend settings.
# The gateway backend handles the communication with the gateway(s) part of
# the LoRaWAN network.
[network_server.gateway.backend]
# Backend
type="mqtt"
# MQTT gateway backend settings.
# This is the backend communicating with the LoRa gateways over a MQTT broker.
# MQTT topic templates for the different MQTT topics.
# The meaning of these topics are documented at:
# https://www.chirpstack.io/gateway-bridge/
# The default values match the default expected configuration of the
# ChirpStack Gateway Bridge MQTT backend. Therefore only change these values when
# absolutely needed.
# Event topic template.
event_topic="gateway/+/event/+"
# Command topic template.
# Use:
# * "{{ .GatewayID }}" as an substitution for the LoRa gateway ID
# * "{{ .CommandType }}" as an substitution for the command type
command_topic_template="gateway/{{ .GatewayID }}/command/{{ .CommandType }}"
server="tcp://localhost:1883"
username=""
password=""
# Metrics collection settings.
[metrics]
# Timezone
# The timezone is used for correctly aggregating the metrics (e.g. per hour,
# day or month).
# Example: "Europe/Amsterdam" or "Local" for the the system's local time zone.
timezone="Local"
# Join-server settings.
[join_server]
# Default join-server settings.
# This join-server will be used when resolving the JoinEUI is set to false
# or as a fallback when resolving the JoinEUI fails.
[join_server.default]
# hostname:port of the default join-server
# This API is provided by ChirpStack Application Server.
#server="http://localhost:8003"
server="http://server_ip:8003"
AS:
# This configuration sets the required settings and configures an integration
# with a MQTT broker. Many options and defaults have been omitted for
# simplicity.
# See https://www.chirpstack.io/application-server/install/config/ for a full
[general]
log_level=4
[postgresql]
# 'user=chirpstack_as dbname=chirpstack_as sslmode=disable'.
#dsn="postgres://localhost/chirpstack_as?sslmode=disable"
dsn="postgres://chirpstack_as:dbpassword@localhost/chirpstack_as?sslmode=disable"
# Redis settings
[redis]
# Application-server settings.
[application_server]
# Integration configures the data integration.
# This is the data integration which is available for all applications,
# besides the extra integrations that can be added on a per-application
# basis.
# Enabled integrations.
enabled=["mqtt"]
# MQTT integration backend.
# https://www.chirpstack.io/application-server/integrate/data/
# The following substitutions can be used:
# * "{{ .ApplicationID }}" for the application id.
# * "{{ .DevEUI }}" for the DevEUI of the device.
# Note: the downlink_topic_template must contain both the application id and
# DevEUI substitution!
uplink_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/rx"
downlink_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/tx"
join_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/join"
ack_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/ack"
error_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/error"
status_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/status"
location_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/location"
username=""
password=""
# Settings for the "internal api"
# This is the API used by ChirpStack Network Server to communicate with ChirpStack Application Server
# and should not be exposed to the end-user.
[application_server.api]
#bind="0.0.0.0:8001"
bind="server_ip:8001"
# Public ip:port of the application-server API.
# This is used by ChirpStack Network Server to connect to ChirpStack Application Server. When running
# ChirpStack Application Server on a different host than ChirpStack Network Server, make sure to set
# this to the host:ip on which ChirpStack Network Server can reach ChirpStack Application Server.
# The port must be equal to the port configured by the 'bind' flag
# above.
#public_host="localhost:8001"
public_host="server_ip:8001"
#public_host="0.0.0.0:8001"
# Settings for the "external api"
# This is the API and web-interface exposed to the end-user.
# ip:port to bind the (user facing) http server to (web-interface and REST / gRPC api)
bind="0.0.0.0:8080"
#bind="server_ip:8080"
# http server TLS certificate (optional)
tls_cert=""
# http server TLS key (optional)
tls_key=""
# JWT secret used for api authentication / authorization
# You could generate this by executing 'openssl rand -base64 32' for example
jwt_secret=""
# Join-server configuration.
# ChirpStack Application Server implements a (subset) of the join-api specified by the
# LoRaWAN Backend Interfaces specification. This API is used by ChirpStack Network Server
# to handle join-requests.
[join_server]
# ip:port to bind the join-server api interface to
bind="0.0.0.0:8003"
#bind="server_ip:8003"
