I’m trying to get Chirpstack working with our RAK7249 gateway. We have successfully configured basic station on the gateway and got the gateway communicating with the Chirpstack network server. So we have made it that far. So I added a Dragino LHT65 device under a new application and had it join. The issue is that it gets through a join and then after the first post-join downlink it seems to get stuck on US915 channel 65. First off, I don’t know why the gateway won’t receive under this channel, but second why is it always wanting to transmit on this channel. I believe we have the network server configured correctly in Chirpstack, but maybe we are missing something. This LHT65 joins TTN just fine.
Here is the behavior of the LHT65:
Gateway Bridge Config:
servers=["tcp://mosquitto:1883"]
username=""
password=""
[backend]
type="basic_station"
[backend.basic_station]
bind=":3002"
stats_interval="30s"
ping_interval="1m0s"
# Read timeout.
# This interval must be greater than the configured ping interval.
read_timeout="1m5s"
# Write timeout.
write_timeout="1s"
# Region.
# Please refer to the LoRaWAN Regional Parameters specification
# for the complete list of common region names.
region="US915"
# Minimal frequency (Hz).
frequency_min=902000000
# Maximum frequency (Hz).
frequency_max=928000000
# Concentrator configuration.
# This section contains the configuration for the SX1301 concentrator chips.
# Example:
[[backend.basic_station.concentrators]]
# Multi-SF channel configuration.
[backend.basic_station.concentrators.multi_sf]
# Frequencies (Hz).
frequencies=[
903900000,
904100000,
904300000,
904500000,
904700000,
904900000,
905100000,
905300000
# LoRa STD channel.
[backend.basic_station.concentrators.lora_std]
# Frequency (Hz).
frequency=904600000
# Bandwidth (Hz).
bandwidth=500000
# Spreading factor.
spreading_factor=8
Network Server Config:
[general]
# Log level
log_level=4
[postgresql]
dsn="postgres://chirpstack_ns:chirpstack_ns@postgresql/chirpstack_ns?sslmode=disable"
[redis]
url="redis://redis:6379"
[network_server]
net_id="000000"
deduplication_delay="200ms"
device_session_ttl="744h0m0s"
get_downlink_data_delay="100ms"
[network_server.band]
name="US915"
uplink_dwell_time_400ms=false
downlink_dwell_time_400ms=false
uplink_max_eirp=-1
repeater_compatible=false
enabled_uplink_channels=[8, 9, 10, 11, 12, 13, 14, 15, 65]
installation_margin=10
rx_window=0
rx1_delay=1
rx1_dr_offset=0
rx2_dr=-1
rx2_frequency=-1
rx2_prefer_on_rx1_dr_lt=0
gateway_prefer_min_margin=10
ownlink_tx_power=-1
disable_mac_commands=false
disable_adr=false
max_mac_command_error_count=3
[network_server.network_settings.class_b]
ping_slot_dr=0
ping_slot_frequency=0
[network_server.network_settings.rejoin_request]
enabled=false
max_count_n=0
max_time_n=0
[network_server.scheduler]
scheduler_interval="1s"
[network_server.scheduler.class_c]
device_downlink_lock_duration="2s"
gateway_downlink_lock_duration="0s"
multicast_gateway_delay="2s"
[network_server.api]
bind="0.0.0.0:8000"
[network_server.gateway]
client_cert_lifetime="8760h0m0s"
force_gws_private=false
downlink_timeout="1s"
[network_server.gateway.backend]
type="mqtt"
multi_downlink_feature="hybrid"
server="tcp://mosquitto:1883"
max_reconnect_interval="1m0s"
qos=0
clean_session=true
client_id=""
[join_server]
resolve_join_eui=false
[join_server.default]
server="http://chirpstack-application-server:8003"
