Hi. I’m new to chirpstack. The Network Server is failing to start and im not sure why. The fail message doesn’t make sense to me.
I’ve included the snips i think are relevant followed by the complete log file and configuration file.
Thanks for your assistance.
log message:
chirpstack-network-server[2507]: time="2019-12-31T16:16:52-05:00" level=fatal msg="read configuration file error" error="While parsing config: (73, 8): duplicated tables"
line 72,73 of config file:
# Max idle connections in the pool.
max_idle=10
complete log:
Dec 31 16:16:52 epadmin systemd[1]: Stopped ChirpStack Network Server.
Dec 31 16:16:52 epadmin systemd[1]: Started ChirpStack Network Server.
Dec 31 16:16:52 epadmin chirpstack-network-server[2507]: time="2019-12-31T16:16:52-05:00" level=fatal msg="read configuration file error" error="While parsing config: (73, 8): duplicated tables"
Dec 31 16:16:52 epadmin systemd[1]: chirpstack-network-server.service: Main process exited, code=exited, status=1/FAILURE
Dec 31 16:16:52 epadmin systemd[1]: chirpstack-network-server.service: Failed with result 'exit-code'.
Dec 31 16:16:52 epadmin systemd[1]: chirpstack-network-server.service: Service hold-off time over, scheduling restart.
Dec 31 16:16:52 epadmin systemd[1]: chirpstack-network-server.service: Scheduled restart job, restart counter is at 5.
Dec 31 16:16:52 epadmin systemd[1]: chirpstack-network-server.service: Start request repeated too quickly.
Dec 31 16:16:52 epadmin systemd[1]: Failed to start ChirpStack Network Server.
complete config file:
[general]
# Log level
log_level=4
# PostgreSQL settings.
# Please note that PostgreSQL 9.5+ is required.
[postgresql]
# PostgreSQL dsn (e.g.: postgres://user:password@hostname/database?sslmode=disable).
# Besides using an URL (e.g. 'postgres://user:password@hostname/database?sslmode=disable')
# it is also possible to use the following format:
# 'user=chirpstack_ns dbname=chirpstack_ns sslmode=disable'.
# The following connection parameters are supported:
# * dbname - The name of the database to connect to
# * user - The user to sign in as
# * password - The user's password
# * host - The host to connect to. Values that start with / are for unix domain sockets. (default is localhost)
# * port - The port to bind to. (default is 5432)
# * sslmode - Whether or not to use SSL (default is require, this is not the default for libpq)
# * fallback_application_name - An application_name to fall back to if one isn't provided.
# * connect_timeout - Maximum wait for connection, in seconds. Zero or not specified means wait indefinitely.
# * sslcert - Cert file location. The file must contain PEM encoded data.
# * sslkey - Key file location. The file must contain PEM encoded data.
# * sslrootcert - The location of the root certificate file. The file must contain PEM encoded data.
# Valid values for sslmode are:
# * disable - No SSL
dsn="postgres://localhost/chirpstack_ns?sslmode=disable"
# Automatically apply database migrations.
# It is possible to apply the database-migrations by hand
# (see https://github.com/brocaar/chirpstack-network-server/tree/master/migrations)
# or let ChirpStack Application Server migrate to the latest state automatically, by using
# this setting. Make sure that you always make a backup when upgrading ChirpStack
# Application Server and / or applying migrations.
automigrate=true
# Max open connections.
# PostgreSQL connection pool (0 = unlimited).
max_open_connections=0
# Max idle connections.
# This sets the max. number of idle connections in the PostgreSQL connection
# pool (0 = no idle connections are retained).
max_idle_connections=2
# Redis settings
# Please note that Redis 2.6.0+ is required.
[redis]
# Redis url (e.g. redis://user:password@hostname/0)
# For more information about the Redis URL format, see:
# https://www.iana.org/assignments/uri-schemes/prov/redis
url="redis://localhost:6379"
max_idle=10
# Idle timeout.
# Close connections after remaining idle for this duration. If the value
# is zero, then idle connections are not closed. You should set
# the timeout to a value less than the server's timeout.
idle_timeout="5m0s"
# Max active connections in the pool.
# When zero, there is no limit on the number of connections in the pool.
max_active=0
# Network-server settings.
[network_server]
# Network identifier (NetID, 3 bytes) encoded as HEX (e.g. 010203)
net_id="000000"
# Time to wait for uplink de-duplication.
# This is the time that ChirpStack Network Server will wait for other gateways to receive
# the same uplink frame. Valid units are 'ms' or 's'.
# Please note that this value has influence on the uplink / downlink
# roundtrip time. Setting this value too high means ChirpStack Network Server will be
# unable to respond to the device within its receive-window.
deduplication_delay="200ms"
# Device session expiration.
# The TTL value defines the time after which a device-session expires
# after no activity. Valid units are 'ms', 's', 'm', 'h'. Note that these
# values can be combined, e.g. '24h30m15s'.
device_session_ttl="744h0m0s"
# Get downlink data delay.
# This is the time that ChirpStack Network Server waits between forwarding data to the
# application-server and reading data from the queue. A higher value
# means that the application-server has more time to schedule a downlink
# queue item which can be processed within the same uplink / downlink
# transaction.
get_downlink_data_delay="100ms"
# LoRaWAN regional band configuration.
# Note that you might want to consult the LoRaWAN Regional Parameters
# specification for valid values that apply to your region.
# See: https://www.lora-alliance.org/lorawan-for-developers
[network_server.band]
# LoRaWAN band to use.
# Valid values are:
# * AS_923
# * AU_915_928
# * CN_470_510
# * CN_779_787
# * EU_433
# * EU_863_870
# * IN_865_867
# * KR_920_923
# * RU_864_870
# * US_902_928
name="US_902_928"
# Enforce 400ms dwell time.
# Some regions require the configuration of the dwell time, which will
# limit the time-on-air to 400ms. Please refer to the LoRaWAN Regional
# Parameters specification for more information.
# When configured and required in the configured region, ChirpStack Network Server will
# use the TxParamSetup mac-command to communicate this to the devices.
uplink_dwell_time_400ms=false
downlink_dwell_time_400ms=false
# Uplink max. EIRP.
# This defines the maximum allowed device EIRP which must be configured
# for some regions. Please refer the LoRaWAN Regional Parameters specification
# for more information. Set this to -1 to use the default value for this
# region.
# When required in the configured region, ChirpStack Network Server will use the
# TxParamSetup mac-command to communicate this to the devices.
# For regions where the TxParamSetup mac-command is not implemented, this
# setting is ignored.
uplink_max_eirp=-1
# Enforce repeater compatibility.
# Most band configurations define the max payload size for both an optional
# repeater encapsulation layer as for setups where a repeater will never
# be used. The latter case increases the max payload size for some data-rates.
# In case a repeater might used, set this flag to true.
repeater_compatible=false
# LoRaWAN network related settings.
# surrounded gateways.
installation_margin=10
# RX window (Class-A).
# Set this to:
# 0: RX1 / RX2
# 1: RX1 only
# 2: RX2 only
rx_window=0
# Class A RX1 delay
# 0=1sec, 1=1sec, ... 15=15sec. A higher value means ChirpStack Network Server has more
# time to respond to the device as the delay between the uplink and the
# first receive-window will be increased.
rx1_delay=1
# RX1 data-rate offset
# Please consult the LoRaWAN Regional Parameters specification for valid
# options of the configured network_server.band.name.
rx1_dr_offset=0
# RX2 data-rate
# When set to -1, the default RX2 data-rate will be used for the configured
# LoRaWAN band.
rx2_dr=-1
# RX2 frequency
# When set to -1, the default RX2 frequency will be used.
rx2_frequency=-1
rx2_prefer_on_rx1_dr_lt=0
# Prefer RX2 on link budget.
# Downlink TX Power (dBm)
# be used.
downlink_tx_power=-1
# Disable mac-commands
# When set to true, ChirpStack Network Server will not handle and / or schedule any
# mac-commands. However, it is still possible for an external controller
# to handle and / or schedule mac-commands. This is intended for testing
# only.
disable_mac_commands=false
# Disable ADR
# When set, this globally disables ADR.
disable_adr=false
# Max mac-command error count.
# When a mac-command is nACKed for more than the configured value, then the
# ChirpStack Network Server will stop sending this mac-command to the device.
# This setting prevents that the Network Server will keep sending mac-commands
# on every downlink in case of a malfunctioning device.
max_mac_command_error_count=3
# Enable only a given sub-set of channels
# Use this when ony a sub-set of the by default enabled channels are being
# used. For example when only using the first 8 channels of the US band.
# Note: when left blank, all channels will be enabled.
# Example:
# enabled_uplink_channels=[0, 1, 2, 3, 4, 5, 6, 7]
enabled_uplink_channels=[8,9,10,11,12,13,14,15]
# Extra channel configuration.
# Use this for LoRaWAN regions where it is possible to extend the by default
# available channels with additional channels (e.g. the EU band).
# The first 5 channels will be configured as part of the OTAA join-response
# (using the CFList field).
# The other channels (or channel / data-rate changes) will be (re)configured
# using the NewChannelReq mac-command.
# Example:
# [[network_server.network_settings.extra_channels]]
# frequency=867100000
# min_dr=0
# max_dr=5
# frequency=867300000
# min_dr=0
# max_dr=5
# frequency=867500000
# min_dr=0
# max_dr=5
# frequency=867700000
# min_dr=0
# max_dr=5
# frequency=867900000
# min_dr=0
# max_dr=5
# Class B settings
[network_server.network_settings.class_b]
# Ping-slot data-rate.
ping_slot_dr=0
# Ping-slot frequency (Hz)
# Set this to 0 to use the default frequency plan for the configured region
ping_slot_frequency=0
# Rejoin-request settings
# When enabled, ChirpStack Network Server will request the device to send a rejoin-request
# every time when one of the 2 conditions below is met (frame count or time).
[network_server.network_settings.rejoin_request]
# Request device to periodically send rejoin-requests
enabled=false
# The device must send a rejoin-request type 0 at least every 2^(max_count_n + 4)
# uplink messages. Valid values are 0 to 15.
max_count_n=0
# The device must send a rejoin-request type 0 at least every 2^(max_time_n + 10)
# seconds. Valid values are 0 to 15.
# 0 = roughly 17 minutes
# 15 = about 1 year
max_time_n=0
# Scheduler settings
# These settings affect the multicast, Class-B and Class-C downlink queue
# scheduler.
[network_server.scheduler]
# Scheduler interval
# The interval in which the downlink scheduler for multicast, Class-B and
# Class-C runs.
scheduler_interval="1s"
# Class-C settings.
[network_server.scheduler.class_c]
# Downlink lock duration
# Contains the duration to lock the downlink Class-C transmissions
# after a preceeding downlink tx (per device).
downlink_lock_duration="2s"
# Multicast gateway delay.
# In case of a multi-gateway multicast downlink, this delay will added to
# the transmission time of each downlink to avoid collisions between overlapping
# gateways.
multicast_gateway_delay="2s"
# Network-server API
# This is the network-server API that is used by ChirpStack Application Server or other
# custom components interacting with ChirpStack Network Server.
[network_server.api]
bind="0.0.0.0:8000"
# ca certificate used by the api server (optional)
ca_cert=""
# tls certificate used by the api server (optional)
tls_cert=""
# tls key used by the api server (optional)
tls_key=""
# Backend defines the gateway backend settings.
# The gateway backend handles the communication with the gateway(s) part of
# the LoRaWAN network.
[network_server.gateway.backend]
# Backend
# This defines the backend to use for the communication with the gateways.
# Use the section name of one of the following gateway backends.
# Valid options are:
# * mqtt
# * amqp
# * gcp_pub_sub
# * azure_iot_hub
type="mqtt"
# MQTT gateway backend settings.
# This is the backend communicating with the LoRa gateways over a MQTT broker.
# MQTT topic templates for the different MQTT topics.
# The meaning of these topics are documented at:
# https://www.chirpstack.io/gateway-bridge/
# The default values match the default expected configuration of the
# ChirpStack Gateway Bridge MQTT backend. Therefore only change these values when
# absolutely needed.
# Event topic template.
event_topic="gateway/+/event/+"
# Command topic template.
# Use:
# * "{{ .GatewayID }}" as an substitution for the LoRa gateway ID
# * "{{ .CommandType }}" as an substitution for the command type
command_topic_template="gateway/{{ .GatewayID }}/command/{{ .CommandType }}"
server="tcp://localhost:1883"
username=""
password=""
# Quality of service level
# 0: at most once
# 1: at least once
# 2: exactly once
qos=0
# Clean session
clean_session=true
# Client ID
client_id=""
ca_cert=""
tls_cert=""
# TLS key file (optional)
tls_key=""
# AMQP / RabbitMQ.
# Use this backend when the ChirpStack Gateway Bridge is configured to connect
# to RabbitMQ using the MQTT plugin. See for more details about this plugin:
# https://www.rabbitmq.com/mqtt.html
[network_server.gateway.backend.amqp]
# Server URL.
# See for a specification of all the possible options:
# https://www.rabbitmq.com/uri-spec.html
url="amqp://guest:guest@localhost:5672"
# Event queue name.
# This queue will be created when it does not yet exist and is used to
# queue the events received from the gateway.
event_queue_name="gateway-events"
# Event routing key.
# This is the routing-key used for creating the queue binding.
event_routing_key="gateway.*.event.*"
# Command routing key template.
# This is the command routing-key template used when publishing gateway
# commands.
command_routing_key_template="gateway.{{ .GatewayID }}.command.{{ .CommandType }}"
# Google Cloud Pub/Sub backend.
# to the Google Cloud IoT Core MQTT broker (which integrates with Pub/Sub).
[network_server.gateway.backend.gcp_pub_sub]
# Path to the IAM service-account credentials file.
# Note: this service-account must have the following Pub/Sub roles:
# * Pub/Sub Editor
credentials_file=""
# Google Cloud project id.
project_id=""
# Uplink Pub/Sub topic name (to which Cloud IoT Core publishes).
uplink_topic_name=""
# Downlink Pub/Sub topic name (for publishing downlink frames).
downlink_topic_name=""
# Uplink retention duration.
# The retention duration that ChirpStack Network Server will set on the uplink subscription.
uplink_retention_duration="24h0m0s"
# Azure IoT Hub backend.
# to the Azure IoT Hub MQTT broker.
[network_server.gateway.backend.azure_iot_hub]
# Events connection string.
# This connection string must point to the Service Bus Queue to which the
# IoT Hub is forwarding the (uplink) gateway events.
events_connection_string=""
# Commands connection string.
# This connection string must point to the IoT Hub and is used by ChirpStack Network Server
# for sending commands to the gateways.
commands_connection_string=""
# Geolocation settings.
# When set, ChirpStack Network Server will use the configured geolocation server to
# resolve the location of the devices.
[geolocation_server]
# Server.
# The hostname:ip of the geolocation service (optional).
server=""
# CA certificate used by the API client (optional).
ca_cert=""
# TLS certificate used by the API client (optional).
tls_cert=""
# TLS key used by the API client (optional).
tls_key=""
# Metrics collection settings.
[metrics]
# Timezone
# The timezone is used for correctly aggregating the metrics (e.g. per hour,
# day or month).
# Example: "Europe/Amsterdam" or "Local" for the the system's local time zone.
timezone="Local"
# Metrics stored in Redis.
# The following metrics are stored in Redis:
# * gateway statistics
[metrics.redis]
# Aggregation intervals
# The intervals on which to aggregate. Available options are:
# 'MINUTE', 'HOUR', 'DAY', 'MONTH'.
aggregation_intervals=["MINUTE", "HOUR", "DAY", "MONTH"]
# Aggregated statistics storage duration.
minute_aggregation_ttl="2h0m0s"
hour_aggregation_ttl="48h0m0s"
day_aggregation_ttl="2160h0m0s"
month_aggregation_ttl="17520h0m0s"
# Metrics stored in Prometheus.
# These metrics expose information about the state of the ChirpStack Network Server
# instance.
[metrics.prometheus]
# Enable Prometheus metrics endpoint.
endpoint_enabled=false
# The ip:port to bind the Prometheus metrics server to for serving the
# metrics endpoint.
bind=""
# API timing histogram.
# By setting this to true, the API request timing histogram will be enabled.
# See also: https://github.com/grpc-ecosystem/go-grpc-prometheus#histograms
api_timing_histogram=false
# Join-server settings.
[join_server]
# Resolve JoinEUI (experimental).
# Default join-server settings.
# When set to true, ChirpStack Network Server will use the JoinEUI to resolve the join-server
# for the given JoinEUI. ChirpStack Network Server will fallback on the default join-server
# when resolving the JoinEUI fails.
resolve_join_eui=false
# Resolve domain suffix.
# This configures the domain suffix used for resolving the join-server.
resolve_domain_suffix=".joineuis.lora-alliance.org"
# Join-server certificates.
# Example:
# [[join_server.certificates]]
# # JoinEUI.
# # The JoinEUI of the joinserver to to use the certificates for.
# join_eui="0102030405060708"
# # CA certificate (optional).
# # Set this to validate the join-server server certificate (e.g. when the
# # certificate was self-signed).
# ca_cert="/path/to/ca.pem"
# # TLS client-certificate (optional).
# # Set this to enable client-certificate authentication with the join-server.
# tls_cert="/path/to/tls_cert.pem"
# # TLS client-certificate key (optional).
# tls_key="/path/to/tls_key.pem"
# This join-server will be used when resolving the JoinEUI is set to false
# or as a fallback when resolving the JoinEUI fails.
[join_server.default]
# hostname:port of the default join-server
# This API is provided by ChirpStack Application Server.
server="http://localhost:8003"
# ca certificate used by the default join-server client (optional)
ca_cert=""
# tls certificate used by the default join-server client (optional)
tls_cert=""
# tls key used by the default join-server client (optional)
tls_key=""
# Join-server KEK set.
# These KEKs (Key Encryption Keys) are used to decrypt the network related
# session-keys received from the join-server on a (re)join-accept.
# Please refer to the LoRaWAN Backend Interface specification
# 'Key Transport Security' section for more information.
# Example (the [[join_server.kek.set]] can be repeated):
# [[join_server.kek.set]]
# # KEK label.
# label="000000"
# # Key Encryption Key.
# kek="01020304050607080102030405060708"
# Network-controller configuration.
[network_controller]
# hostname:port of the network-controller api server (optional)
server=""
# ca certificate used by the network-controller client (optional)
ca_cert=""
# tls certificate used by the network-controller client (optional)
tls_cert=""
# tls key used by the network-controller client (optional)
tls_key=""
