I have an issue with a sensor (NKE Modbus Bridge) at one particular gateway: in the grafic below you can see that after the initial join, a downlink is sent to the sensor for each uplink received. After x Uplinks (not consistent), the sensor stops sending Uplinks. Some time (not consitent) later, he will send again a Join request to restart the cycle.
The Sensor supports LoRaWAN 1.0.2. and is setup as Class C Device with OTAA. A second sensor is working fine (connected through another gateway and different organization to the same network server).
Step 1
The phyPayload of the first uplink looks as follow:
"phyPayload": {
"mhdr": {"mType": "UnconfirmedDataUp","major": "LoRaWANR1"},
"macPayload": {
"fhdr": {
"devAddr": "0181707c",
"fCtrl": {
"adr": true,
"adrAckReq": false,
"ack": false,
"fPending": false,
"classB": false},
"fCnt": 0,
"fOpts": null
"fPort": null,
"frmPayload": null
"mic": "f2613547"
Step 2
The network-server immediately sends the first downlink:
"phyPayload": {
"mhdr": {"mType": "UnconfirmedDataDown", "major": "LoRaWANR1"},
"macPayload": {
"fhdr": {
"fCtrl": {
"adr": true,
"adrAckReq": false,
"ack": false,
"fPending": false,
"classB": false
"fCnt": 0,
"fOpts": [
"cid": "LinkADRReq",
"payload": {
"dataRate": 5,
"txPower": 0,
"chMask": [true,true,true,true,true,true,true,true,false,false,false,false,false,false,false,false],
"redundancy": {
"chMaskCntl": 0,
"nbRep": 1
"cid": "DevStatusReq",
"payload": null
"fPort": null,
"frmPayload": null
"mic": "a8e05de7"
Two MAC commands are contained:
LinkADRReq: requesting the sensor to perform a rate adaptation to dataRate 5 -
DevStatusReq: requesting status information. According to LoRaWAN specs, the sensor must respond withDevStatusAns.
Step 3
This is followed again by the second uplink:
"phyPayload": {
"macPayload": {
"fhdr": {
"fCtrl": {
"adr": true,
"adrAckReq": false,
"ack": false,
"fPending": false,
"classB": false
"fCnt": 1,
"fOpts": [
"payload": {
"channelMaskAck": true,
"dataRateAck": true,
"powerAck": true
"payload": {
"battery": 0,
"margin": -10
"fPort": null,
"frmPayload": null
"mic": "408a0929"
Apparently, the sensor acknowledged the LinkADRReq and responded to the DevStatusReq.
According to the LoRaWAN specs, he should however do so with LinkADRAns and DevStatusAns.
Step 4
The network server sends an immediate downlink again:
"phyPayload": {
"mhdr": {"mType": "UnconfirmedDataDown","major": "LoRaWANR1"},
"macPayload": {
"fhdr": {
"fCtrl": {
"adr": true,
"adrAckReq": false,
"ack": false,
"fPending": false,
"classB": false
"fCnt": 1,
"fOpts": [
"payload": {
"dataRate": 5,
"txPower": 2,
"redundancy": {
"chMaskCntl": 0,
"nbRep": 1
"fPort": null,
"frmPayload": null
"mic": "d8e05f48"
This time, only LinkADRReq is send.
Step 5
The sensor comes back with the following uplink:
"phyPayload": {
"macPayload": {
"fhdr": {
"fCtrl": {
"adr": true,
"adrAckReq": false,
"ack": false,
"fPending": false,
"classB": false
"fCnt": 2,
"fOpts": null
"fPort": 125,
"frmPayload": [
"bytes": "NiLnCxlbWQXj7XnUYNk/ubgYW4mVogb3ze6Yc21ACg=="
"mic": "43999959"
The LinkADRReq has been completly ignored, the sensor sends only regular payload.
Now the cyclic behavior starts:
- an upload arrives (without any MacCommands) (message as in Step 5)
- a downlink is send with
LinkADRReq(message as in Step 4)
After some time, the sensor stops sending uplinks. Some time later, it rejoins the network. This has been consistent over the last few days, with typically 5-200 iterations and 30-90min breaks in between.
Any idea how to stop this / what might cause this?
