Hi
Does anyone have experience to get that Modbus Bridge running with Chirpstack.
http://support.nke-watteco.com/modbus/
I like to read some given Modbus Register to a influxdb…
Thanks in advance…
Hi
Thanks in advance…
No, but thank you for posting the link - very interesting!
Me again…
In the meantime, I have had the Watteco Modbus adapter integrated with a commercial provider. He wrote drivers for it, written in Golang,afaik. Who could help to encode the data with the builtin function of Chirpstack?? The provider can only offer its own platform, which I can’t use in the test phase yet.
If I copy the output from Devicedata and paste it here, I already get data. For example, the correct Modbus address is there to see. Output: " EQqABwABQRE3Aw5fQF8AADNxtgsOAKUAIw== "
https://support.nke.fr/Lora/index.php
`{“version”: “NKE_Frame_Codec_v_1.0.svn5087”, “TimeStamp”: “2022-11-22 09:48:53.471599”}
“EndPoint”: 0,
“Report”: “Standard”,
“CommandID”: “ReportAttributes”,
“ClusterID”: “SerialMasterSlave”,
“AttributeID”: “Answer”,
“AttributeType”: “ByteString”,
“Data”: {
“ModBusAnswer”: {
“SlaveID”: 55,
“FcntID”: 3,
“DataSize”: 14,
“Data”: “5f405f00003371b60b0e00a50023”
“Cause”:
The content of “Data” at the end is then certainly the data, which is available as a hex value, I assume.
There are a few JavaScript examples on the manufacturer’s website, but none of them work.
How do I get there? Who could help.?
Btw. I’m still using V3, but would go to V4 if the rollout to three datacenter will start…
Thanks in advance
The “5f405f00003371b60b0e00a50023” is the modbus register which depends of your slave. So you need to know the format of registers of your slave to decode this data.
best regards,
Hi Mathieu
Yes, and i know this. And when i put the received payload from Chipstack
EQqABwABQRE3Aw5fAF8AADNxOQl5AKMAMQ==
to this site
i get that to hex data decoded. But how to do this with a JS decoder?
This is what i’ve written down to do the decoding and calculating by hand…
Decoded:
110a80070001411137030e5f005f0000337139097900a30031
Data:
5f00 5f00 0033 7139 0979 00a3 0031
Reg: Hex: Dez:
1081 5f00 24320 / 1984 = 12,25 Volt
1082 5f00 24320
1083H 0033 51
1083L 7139 28985
1084 0979 2450
1085 00a3 163
1068 0031 49
Hi Rudi,
I think that’s what you’re looking for: Codec-Report-Standard-Javascript/decodeZCL.js at main · Watteco/Codec-Report-Standard-Javascript · GitHub
node decodeZCL.js 125 110a80070001411137030e5f405f00003371b60b0e00a50023
lora: {
port: 125,
payload: ‘110A80070001411137030E5F405F00003371B60B0E00A50023’,
date: ‘2022-12-07T14:51:59.605Z’
zclheader: {
report: ‘standard’,
endpoint: 0,
cmdID: ‘0x0A’,
clusterdID: ‘0x8007’,
attributID: ‘0x0001’
data: {
payload: ‘37030E5F405F00003371B60B0E00A50023’,
modbus_payload: ‘5F405F00003371B60B0E00A50023’,
modbus_float: 0,
modbus_address: 55,
modbus_commandID: 3,
modbus_size: 14
“custom java script field” inside Chirpstack?
Afaik i already have tried this… But gave my only errors…
But yes, i think that files has to be modified. Especialy that part:
//modbus
if ( (clusterdID === 0x8007 ) & (attributID === 0x0001))
decoded.data.payload = "";
decoded.data.modbus_payload = "";
decoded.data.size = bytes[index];
decoded.data.modbus_float = 0; // 0: pas de décodage float 1: décodage float 2: décodage float 2word inversé
for( var j = 0; j < decoded.data.size; j++
Hi Rudi,
Here’s what I have with a modified codec into chirpstack V4…
Could you explain that a little more. I currently have a (dockerized) Chipstack V3. Should that make a difference? What decoder did you use?
… same codec unmodified with V3
this is the codec I used for your test: lorawan-devices/modbus-sensor.js at master · TheThingsNetwork/lorawan-devices · GitHub
… this is the result with the modified codec in v3:
WTF, that means, it depends on v3 vs v4. But why should that happen??
On my production v3 i can’t switch to v4 so fast… So much customising with influx, telegraf and so on.
But i could install a new v4 in a vhost and connect my GW to it… Maybe. But to be honest, it would be better to understand, why this happens…
@brocaar
Thanks for your tests and support…
Keep in mind… Main features and changes with 4.0.0
JavaScript codec engine
The JavaScript codec engine is based on QuickJS, which is an embeddable JavaScript engine which supports the ES2020 specification.
Have changed to v4. Install on Debian11…
Added one of my gateway and the device. User the codec from here.
https://github.com/TheThingsNetwork/lorawan-devices/blob/master/vendor/nke-watteco/modbus-sensor.js
but:
You made some mods??
changes to apply at the end of the codec:
//function decodeUplink(input) {
// const decodedInput = {
// data: Decoder(input.bytes, input.fPort),
// warnings: [],
// errors: []
// return decodedInput.data.data
return {
data: {
bytes: Decoder(input.bytes, input.fPort)
warnings: [], // optional
errors: [] // optional (if set, the decoding failed)
Yeah, that’s it. Now the codec is decoding to the hex payload… Thanks for your support.
The next step would be to convert the individual hex bytes to decimal and do the math to have the analog value. Am I right that this is also done in the JS code and do you know a source with an example?
Cheers, Rüdiger
Hi Rudi,
I need more details concerning the slave behind these number:
…also I think this codec make more sense: Codec-Report-Standard-Javascript/decodeZCL.js at main · Watteco/Codec-Report-Standard-Javascript · GitHub
with these modifications:
//var argv= process.argv.slice(2);
//obj = Decoder(Buffer.from(argv[1],‘hex’),parseInt(argv[0], 10 ));
//console.dir(obj,{depth:null});
warnings: [],
errors: []
return {data: decodedInput.data};
Regards.
Yes, sorry. I had not finished that listing at that time…
Decoded:
Data:
Reg: Hex: Dez:
1081 0x5f00 24320 / 1984 = 12,25 Volt Batt voltage loaded
1082 0x5f00 24320 / 1984 = 12,25 Volt Batt voltage unloaded
1083H 0x00 0 / 15.26 = 0 Ampere Solar panel current
1083L 0x33 51 / 158,39 = 0,32 A. LED current
1084 0x7139 28985 / 4744,35 = 6,10 V. LED voltage
1085 0x0907 2311 / 2949,69 = 0,78 W. Power consumption (w)
1068 0x00a3 (163 / 2) -60 = 21,5 °C Temperature °C
1087 0x0031 Operational state (see table)
Test is running. Have to wait for the next LoRa package…
OK, it is working. Now i would like to understand, how to do the calculation, to have the messurments under “object”
