I’ve followed the install guide and have LoRa Server running on a Ubuntu 16.04 machine.
I’m using a Dragino LG01 for my gateway and a basic node for testing. I’ve had the Dragino and the node connected up to TTN and it’s been working fine for a few weeks.
Now, I’ve changed the settings on the Dragino gateway to point to my new LoRa Server and have created a gateway in the app. The Dragino is connected and is sending data to the LoRa Server so that’s all working fine.
If I connect to the MQTT server then I can see the Dragino gateway sending data. Both status and data from the node.
Back on the LoRa Server app, I have created an application and added a node. I set it to ABP and used the same Device EUI, Application EUI, Device address, Network session key and Application session key that were set in my TTN account.
I expected to see data from the node but nothing is coming through. What have I missed?
