It seems that in chirpstack console we don’t see any downlinks from any of ours ic880a gateways.
They are running with udp semtech packet forwarders in docker based on that image GitHub - netceteragroup/rpi-ttn-gateway: Docker image for Raspberry PI TTN gateway based on Hypriot
Output in the gateway is:
##### 2023-06-20 03:14:50 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 0
# CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
# RF packets forwarded: 0 (0 bytes)
# PUSH_DATA datagrams sent: 1 (220 bytes)
# PUSH_DATA acknowledged: 100.00%
### [DOWNSTREAM] ###
# PULL_DATA sent: 3 (100.00% acknowledged)
# PULL_RESP(onse) datagrams received: 0 (0 bytes)
# RF packets sent to concentrator: 0 (0 bytes)
# TX errors: 0
### [GPS] ###
# Invalid gps time reference (age: 1687230890 sec)
# Manual GPS coordinates: latitude 42.36255, longitude 22.99800, altitude 660 m
##### END #####
INFO: [up] PUSH_ACK for server 78.128.42.83 received in 13 ms
INFO: [down] for server 78.128.42.83 PULL_ACK received in 12 ms
INFO: [down] for server 78.128.42.83 PULL_ACK received in 13 ms
INFO: [down] for server 78.128.42.83 serv_addr[ic]PULL_RESP received :)
INFO: [down] a packet will be sent on timestamp value 833701155
INFO: Downstream Packet RF power to - 14 dBm
However in chirpstack we don’t see any downlink data:
If it is just visualization issue would be ok but in packet log in chirpstack we also don’t see any downlinks.
Our gateway bridge is version=3.14.6
