Hello, in my Chirpstack docker container there works everthing fine, just the events or frames did not load.
Has anyone the same problem, or solved this?
Hi @Ben,
I can see frames from my uplink messages, but did not manage to send any downlink messages.
What about Your gateway status, is it online or?
Best regards,
Filip
Yes the Gateway is online.
And what devices are You using for gateway and end nodes?
What was the process of registering Your gateway?
I have a problem with gateway connection, it won’t go online. I am using Nucleo F746ZG (gateway) and WL55JC1 (end node).
Do You have any idea what could be my problem?
Best regards,
Filip
Doorsensors, soilsensors, Relais
Are you using a proxy, e.g. NGINX? In that case you must add some configuration to make sure the gRPC streaming requests are handled and proxied correctly:
Hi. in my Network, there is no proxy in use.
In some cases, it could be due to a virus scanner at the client-side. In this case the virus scanner intercepts all browser traffic, causing the gRPC stream functionality to break. You will find some topics on the forum about this.
