Data from one of my end-device configured as OTAA is not getting forwarded to http integration. I have compared logs and observed that for this end-device, neither mqtt is publishing message on device rx topic nor http request to my endpoint is getting processed.
I also do not see any device activation filled in for this device, however the device joins and join is accepted. For this I did refer to another thread in this forum https://forum.loraserver.io/t/otaa-failed-debugging-device-activation-otaa-issues/474/34, but that did not help me in identifying the cause.
It will be of great help if you can point me towards fixing the issue.
logs for sensor which has issue
Logs from another sensor to show mqtt publish and http post
thank you in advance
