I’ve probably done something silly, but trying to follow the instructions in the readme for locally building using Nix/docker and I keep getting No rule to make target 'release-amd64'. Stop.
I didn’t include the complete output from make build-ui because it seems to complete successfully, so just the tail end of that is included below and make dev-dep also completed without errors:
Find out more about deployment here:
https://cra.link/deployment
Done in 75.66s.
make[1]: Leaving directory '/home/myusername/repositories/chirpstack/ui'
[nix-shell:~/repositories/chirpstack]$ make dev-dependencies
cargo install cross --version 0.2.5
Ignored package `cross v0.2.5` is already installed, use --force to override
cargo install diesel_cli --version 2.1.0 --no-default-features --features postgres
Ignored package `diesel_cli v2.1.0` is already installed, use --force to override
cargo install cargo-deb --version 1.43.1
Ignored package `cargo-deb v1.43.1` is already installed, use --force to override
cargo install cargo-generate-rpm --version 0.12.1
Ignored package `cargo-generate-rpm v0.12.1` is already installed, use --force to override
[nix-shell:~/repositories/chirpstack]$ make debug-amd64
make: *** No rule to make target 'debug-amd64'. Stop.
[nix-shell:~/repositories/chirpstack]$ make release-amd64
make: *** No rule to make target 'release-amd64'. Stop.
Interestingly I’m getting “sh: line 1: jq: command not found” when running “make dist”.
[nix-shell:~/repositories/chirpstack]$ make dist
cd api && make grpc-web
make[1]: Entering directory '/home/myusername/repositories/chirpstack/api'
cd grpc-web && make
make[2]: Entering directory '/home/myusername/repositories/chirpstack/api/grpc-web'
yarn install
yarn install v1.22.19
[1/4] Resolving packages...
success Already up-to-date.
Done in 0.08s.
mkdir -p common
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/common/common.proto
mkdir -p api
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/api/internal.proto
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/api/user.proto
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/api/tenant.proto
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/api/application.proto
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/api/device_profile.proto
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/api/device_profile_template.proto
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/api/device.proto
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/api/gateway.proto
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/api/multicast_group.proto
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/api/relay.proto
./node_modules/grpc-tools/bin/protoc -I=../proto --js_out=import_style=commonjs:. --grpc-web_out=import_style=commonjs+dts,mode=grpcwebtext:. ../proto/google/api/*.proto
make[2]: Leaving directory '/home/myusername/repositories/chirpstack/api/grpc-web'
make[1]: Leaving directory '/home/myusername/repositories/chirpstack/api'
cd chirpstack && make dist
make[1]: Entering directory '/home/myusername/repositories/chirpstack/chirpstack'
# Keep these in this order, as aarch64 is based on Debian Buster (older),
# the others on Bullseye. For some build scripts we want to build against
# least recent LIBC.
cross build --target aarch64-unknown-linux-musl --release
make[1]: cross: No such file or directory
make[1]: *** [Makefile:15: dist] Error 127
make[1]: Leaving directory '/home/myusername/repositories/chirpstack/chirpstack'
make: *** [Makefile:6: dist] Error 2
I’m going to remove/re-clone the repo and report back in a moment if that fixes it because I tried doing things the wrong way first with cargo build inside docker.
Edit so I’m not commenting too much: reclone did not help. Still seeing “No Rule to make target” for building with Nix
