We were using NODE RED on version 4.0 with no problems.
We updated to version 4.0.1 using : chirpstack-gateway-os-full-update-raspberrypi4-20221114095641.swu
but after reboot of Pi4 was impossible to connect on NODE RED ( IP:1880 ) althought it was enabled.
We disabled and reenabled it through gateway-config, after that we had a succesfull connection but the flows we had built where changed. We build them again and the system start working.
But after 2-3 message transfers connection with NODE RED server was lost again. We tried the disable-enable cycle of NODE RED but the problem persists.
