I have set up Chirpstack using Docker, and have joined an Axioma Qalcosonic W1 water meter via a RAK7268 gateway.
The integration from Chirpstack applivcation to a web hook was failing due to Docker DNS issues.
I installed Chirpstack directly on the server, and migrated the PostgreSQL and Redis databases.
Now the gateway sends frames from the meter, but I am seeing None of the device-sessions for dev_addr resulted in valid MIC dev_addr=fa7cc5e8
Any suggestions?
Despite migrating the data, the GUI reports that This device has not (yet) been activated.
Mar 17 18:28:37 m1 chirpstack[4111392]: 2024-03-17T08:28:37.296291Z INFO up{deduplication_id=e37593ff-a3c6-4790-b0b0-172b0ac4d005}: chirpstack::uplink: Uplink received m_type=UnconfirmedDataUp
Mar 17 18:28:37 m1 chirpstack[4111392]: 2024-03-17T08:28:37.296309Z DEBUG up{deduplication_id=e37593ff-a3c6-4790-b0b0-172b0ac4d005}: chirpstack::uplink: Updating gateway meta-data for uplink frame-set
Mar 17 18:28:37 m1 chirpstack[4111392]: 2024-03-17T08:28:37.297065Z DEBUG up{deduplication_id=e37593ff-a3c6-4790-b0b0-172b0ac4d005}: chirpstack::uplink: Logging uplink frame to Redis Stream
Mar 17 18:28:37 m1 chirpstack[4111392]: 2024-03-17T08:28:37.297408Z TRACE up{deduplication_id=e37593ff-a3c6-4790-b0b0-172b0ac4d005}:data_up: chirpstack::uplink::data: Handling passive-roaming device
Mar 17 18:28:37 m1 chirpstack[4111392]: 2024-03-17T08:28:37.297430Z TRACE up{deduplication_id=e37593ff-a3c6-4790-b0b0-172b0ac4d005}:data_up: chirpstack::uplink::data: Getting device for PhyPayload
Mar 17 18:28:37 m1 chirpstack[4111392]: 2024-03-17T08:28:37.298528Z INFO up{deduplication_id=e37593ff-a3c6-4790-b0b0-172b0ac4d005}:data_up: chirpstack::uplink::data: None of the device-sessions for dev_addr resulted in valid MIC dev_addr=fa7cc5e8
