Can you please help me.
Thanks
I assume you are using a proxy. See also: https://forum.loraserver.io/t/rpc-error-code-unauthenticated-and-live-frame-logs-live-event-disconnected/1093/9.
i have the same problem, could you solve it??
I have the same problem. It seems to have been introduced some time ago on my system that worked fine before.
@brocaar you suggest Redis 5+. is this new? what is the purpose of Redis?
Redis was always a dependency. In order to cache the last X (by default 10) uplink / downlink frames, ChirpStack uses Redis Streams (Introduction to Redis Streams – Redis), this is implemented since Redis 5.0.
“Fortunately” for me the server on which chirpstack was installed and that had the problem was crashed after many years of service so I had to rebuild it. With that, my problem disappeared too.
