when i go to link “application” i got new error
Mar 01 16:37:07 Decast chirpstack-network-server[57539]: time=“2022-03-01T16:37:07.998886257+03:00” level=info msg=“finished unary call with code NotFound” ctx_id=06ab5aaf-8843-4641-8a40-b94f5cde8461 error=“rpc error: code = NotFound desc = object does not exist” grpc.code=NotFound grpc.method=GetDeviceActivation grpc.service=ns.NetworkServerService grpc.start_time=“2022-03-01T16:37:07+03:00” grpc.time_ms=0.432 peer.address=“10.100.102.31:48710” span.kind=server system=grpc
If you are you able to cycle power to sensor, this may be only way b/c not all firmware can handle it otherwise. If your sensor allows setting device to factory settings (which usually reflashes firmware) then you can try this as last resort (just save parameters like keys first, if applicable).
Many things can cause this - you’ll need to dig and figure out which applies to your specific case. Use search function in forum and look for “join request” and/or “join accept”. For example.
