From what I understand about the OIDC feature, I need to assign the newly-created user to an organization/tenant. This is supposed to be done from the registration callback (registration_callback_url).
I tried two ways:
TenantServiceGrpc, with TenantUser containing the desired tenant ID and the user_id value provided as the query parameter to the registration callback. I get an error from Chirpstack that the object (with the user ID) doesn’t exist. After I fail this API call, Chirpstack logs that it deleted the user with the exact same ID.
UserServiceGrpc, to set the User’s isAdmin flag to true. The e-mail address is obtained by reading the user from UserServiceGrpc and creating a new User:
User user = User.newBuilder(theUser).setIsAdmin(true).build();
This procedure completes, but the user created doesn’t have the same visibility as the global “admin” user. Since there’s no way to set the tenant ID, I assumed that it’s a global admin user that I created.
How am I supposed to assign the user to a tenant? Or if it’s possible to create an admin user (that’s okay for my purposes too), how do I do it correctly?
Thank you in advance.
