Hello There,
I’m using multiple gateway and i have some sensors in the “cover range” of both two gateway.
at the begining i see the RSSI pass from one to another and i said greaat it working well and all is combine to make a unique payload message. But today i see some problems
After few days of use. i get one sensor which have initiated over 700 “join” to the network. As if each time it switch gateway it start a new join session.
First impact, it totally flood the table device_join . could i delete all the useless field ?
second and more important problem : after move the sensor from one place to another this one try to reconnect with the error: “validate dev-nonce error”
Is it possible, there is a link between the fact that the sensor use to much join session and the dev-nonce error ???
some one know how to reset the dev-nonce?
i try to delete-recreate the device… without succes.
