Hello @brocaar,
can anybody help me with the integration of OpenID on Chirpstack Application Server with AzureAD?
I only got the message “get authenticator error”. What am I doing wrong?
Is the provided provider_url “https://login.microsoftonline.com/{tenant}/v2.0/.well-known/openid-configuration” correct? Anything else should be okay. What does chirpstack send as request?
Best regards
Skeff839
@brocaar
Can you help me please?
I dont’ find any information. How to configure openID.
I got the following log message
time=“2021-03-24T14:59:48Z” level=error msg=“oidc: new authenticator error” error="get provider error: 404 Not Found: "
with the following configuration:
[application_server.user_authentication.openid_connect]
enabled=true
registration_enabled=true
registration_callback_url=“”
provider_url=“Sign in to your account”
client_id=“MY-ID”
client_secret=“MY-SECRET”
redirect_url=“https://MY-DOMAIN/auth/oidc/callback”
logout_url=“”
login_label=“Login via Azure ActiveDirectory”
I do not have any experience with AzureAD, but I tested the OpenID Connect integration successfully with Auth0.com.
Did you manage to get this working ?
I am also stuck at the same point.
Can I ask how you handled this from the Azure AD side?
I have a fully working ChirpStack config, but when the request is being processed it is expecting ‘email_verified’ as a required value in the token. How did you overcome that? Is there any claim type or method that you used to give the boolean true?
I would have assumed it was as simple as setting DataType to boolean, but it is not working for me. Q to Microsoft on the attempt already tried How to send a claim in a token as a boolean value? - Microsoft Q&A
Whenever Azure sends the token for me it arrives as a string value, and cannot be parsed by the ChirpStack code.
