I have used the Chirpstack OpenWrt Full image for the Raspberry Pi to create a combined gateway and network server, and integrated it with other services. The Gateway uses the WM1302 Pi Hat with a SX1302 LoRa transceiver. There are two web interfaces - one on localhost:80 and the other on localhost:8080, both of which are required to do the full configuration.
I want to have a full Raspbian OS (or perhaps Debian/Ubuntu if that is easier), but have the same behaviour as the OpenWrt system.
I have followed the instructions here (Debian / Ubuntu - ChirpStack open-source LoRaWAN® Network Server documentation), but this only installs the Network and gateway forwarder. Only the localhost:8080 web interface is available.
I would like the concentratord and the Chirpstack interface (on localhost:80) so I can use the same hardware, but also have a full UI and load some proprietary software onto the gateway.
I’ve not been able to find any documentation on how to do this. I can download a single executable for the concentratord-1302, but there is minimal information on how this needs to be set up - just a config file, and nothing on the web-based interface, which allows the user to choose between several LoRa transceivers.
How can I set the remaining parts up? Is there a debian package available? Do I need to manually create services to run the concentratord?
Thanks for any help.
