Hello everyone,
I need to size a solution with 400 gateways and about 30,000 devices, transmitting every 6 hours, so 180,000 messages a day.
The gateways are Kerlink using “ChirpStack MQTT Forwarder”.
What configuration do you suggest based on your experiences?
Thank you in advance.
@brocaar could you help me?
Thanks in advance
180.000 messages a day is ~ 2 messages per second. That is not so much and shouldn’t require a very powerful machine. You can do some testing using GitHub - brocaar/chirpstack-simulator: Simulator utility for the ChirpStack open-source LoRaWAN Network-Server. to test different setups
Thank you very much.
You have a response for every question and the simulation that we do not know is very interesting.
Thank you again.
system
Closed
5
