Hi @brocaar, i have some question regarding the security of the LoraServer.
If we have an IOT operator between the nodes and this server, the AppSKey is only visible to the server? or the IOT operator can see this information?
What is the protection/safe mechanism of share of AppSKey to the Lora server?
Many thanks
Only the devices and the LoRa App Server instance(s) know the root keys. Then LoRa App Server knows of course the AppSKey, the network-server (LoRa App Server) only knows the NwkSKey.
Thanks for the quick and helpful answer
Is there any option to view the AppsKey and NwkSKey in LoRa Server for OTAA communication?
As mentioned, LoRa Server does not know the AppSKey, only LoRa App Server knows and should know this key. This information can be viewed in the UI under:
Or using the API GET /api/devices/{devEUI}/activation
From LoRa Server you can get the device-activation (only NwkSKey!) using this API method: https://github.com/brocaar/loraserver/blob/master/api/ns/ns.proto#L64
