Hello, I’m trying to configure my Cubecell using the OTAA authentication since ABP worked just fine.
I followed the configuration method in https://www.chirpstack.io/application-server/use/devices/#device-provisioning with Generic Arduino LMIC-based devices and the only thing I get is a Join Request, nothing more
I’m using the code from the framework arduinoasmicro650x sensor basic example. I believe I configured the keys well I don’t know why it stays in Join Request.
check the req’s of key settings LSB or MSB into device. is your device profile for that device turned to OTAA ?
The Chirpstack says that the Device EUI field must be entered as LSB and the Application EUI and Application Key in MSB, The device profile is turned to OTAA
https://www.chirpstack.io/application-server/use/devices/#otaa-devices
The cubecell I’m using is the cubecell capsule sensor from heltec.
Here is the Log of the gateway:
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # RF packets forwarded: 1 (23 bytes)
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # PUSH_DATA datagrams sent: 1 (242 bytes)
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # PUSH_DATA acknowledged: 100.00%
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ ### [DOWNSTREAM] ###
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # PULL_DATA sent: 5 (100.00% acknowledged)
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # RF packets sent to concentrator: 0 (0 bytes)
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # TX errors: 0
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # TX rejected (collision packet): 0.00% (req:2, rej:0)
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # TX rejected (collision beacon): 0.00% (req:2, rej:0)
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # TX rejected (too late): 0.00% (req:2, rej:0)
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # TX rejected (too early): 0.00% (req:2, rej:0)
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # BEACON queued: 0
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # BEACON sent so far: 0
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # BEACON rejected: 0
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ ### [PPS] ###
Sun Jan 1 00:24:14 2012 daemon.info lora_pkt_fwd[9417]: REPORT~ # SX1301 time (PPS): 662891248
Sun Jan 1 00:24:22 2012 daemon.info lora_pkt_fwd[9417]: RXTX~ {"rxpk":[{"tmst":670615451,"time":"2011-12-31T23:24:22.272603Z","chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":7.8,"rssi":-28,"size":23,"data":"AAAAAAAAAAAAamXfgcqTa4TG/6Ncc9Y="}]}
Notice the date is wrong because the gateway isn’t connected to internet and can’t update his date.
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ ################## Report at: 2020-08-03 07:59:49 UTC ##################
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ ### [UPSTREAM] ###
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # RF packets received by concentrator: 3
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # RF packets forwarded: 3 (69 bytes)
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA datagrams sent: 3 (728 bytes)
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # PUSH_DATA acknowledged: 100.00%
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ ### [DOWNSTREAM] ###
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # PULL_DATA sent: 6 (100.00% acknowledged)
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # RF packets sent to concentrator: 0 (0 bytes)
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # TX errors: 0
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # BEACON queued: 0
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # BEACON sent so far: 0
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # BEACON rejected: 0
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ ### [PPS] ###
Mon Aug 3 08:59:49 2020 daemon.info lora_pkt_fwd[1646]: REPORT~ # SX1301 time (PPS): 183340377
Mon Aug 3 09:00:08 2020 daemon.info lora_pkt_fwd[1646]: RXTX~ {"rxpk":[{"tmst":202773667,"time":"2020-08-03T08:00:08.479722Z","chan":1,"rfch":1,"freq":868.300000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":10.0,"rssi":-23,"size":23,"data":"AAAAAAAAAAAAamXfgcqTa4Reohickpc="}]}
I thought it could be the date but no, even with the date fixed the problem of Join Request persist.
if device not joins, and you see continious join requests then something wrong in OTAA keys or in DevEUI or all together. try to revert them.
Well, you are right… I change the DevEUI to MSB format and now it works. Welp, that’s the solution, thank you!
