I’m banging my head for this particular problem for over a week now.
I have next configuration:
lopy_node->gw(kersing packet forwarder)->gw_bridge(on gateway)->lora(app)server
When i reset the node the OTAA request gets to lora app server , app server assigns dev_addr, kersing sais that it’s been pushed to concentrator. From the logs it seems to me that the concentrator sends the packet but node doesn’t get it. But if I stop the node to try to Join the network the lora-app is still sending JoinAccept to mqtt broker.
mqtt application/#
{“applicationID”:“2”,“applicationName”:“application”,“deviceName”:“elab-bazz”,“devEUI”:“aaaaddddaaaadddd”,“devAddr”:“00767fe5”}
{“applicationID”:“2”,“applicationName”:“application”,“deviceName”:“elab-bazz”,“devEUI”:“aaaaddddaaaadddd”,“devAddr”:“01ff566d”}
kersin mp_pkt_fwd/#
Jul 02 11:53:18 gwekos03 mp_pkt_fwd[24915]: INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
Jul 02 11:53:18 gwekos03 mp_pkt_fwd[24915]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1114807819
Jul 02 11:53:18 gwekos03 mp_pkt_fwd[24915]: 11:53:18 INFO: [down] for server PULL_ACK received in 1 ms
Jul 02 11:53:26 gwekos03 mp_pkt_fwd[24915]: 11:53:26 INFO: [stats] received packet with valid CRC from mote: 05060708 (fcnt=515)
Jul 02 11:53:26 gwekos03 mp_pkt_fwd[24915]: 11:53:26 INFO: [up] PUSH_ACK for server 127.0.0.1 received in 0 ms
Jul 02 11:53:26 gwekos03 mp_pkt_fwd[24915]: 11:53:26 INFO: [down] for server serv_addr[ic] PULL_RESP received - token[51:76]
Jul 02 11:53:28 gwekos03 mp_pkt_fwd[24915]: 11:53:28 INFO: [down] for server PULL_ACK received in 0 ms
The process then continues to run and is also running if I stop the node. Do you have any idee how I can debug if node recieves anything from this gateway since non private (TTN) implementation works as expected in same configuration. The difference is in packet forwarder routing to loraserver.io
