A similar problem In the topic is discussed and solved with a parameter change in the code, which is also changed in the release.
However, now chirpstack uses different mqtt library for rust. And I have a problem with sending bursty messages from mqtt event up for the gateway.
Here is some experimental results.
Event: up
- 500 packets received from MQTT broker, 134 packets processed at the application server side.
- 500 packets received from MQTT broker, 141 packets processed at the application server side.
- 500 packets received from MQTT broker, 133 packets processed at the application server side.
- 500 packets received from MQTT broker, 139 packets processed at the application server side.
- 1000 packets received from MQTT broker, 283 packets processed at the application server side.
- 1000 packets received from MQTT broker, 285 packets processed at the application server side.
Tried all the suggestions that are given in the topic I shared above, just cannot change the library part. I run the chirpstack on docker.
I wish to receive all packets on the application side that I sent from the MQTT Broker.
If I put a delay between two consecutive packets about 350ms, I can receive all the event:up packets without any problem.
Is it possible to send all of them without putting any delay?
Thank you
