Hi @Curt_Black
Thanks for the reply, Please find below-attached logs.
Aug 5 20:13:11 nbl_ec2x local5.info lora_pkt_fwd: [I] src/lora_pkt_fwd.c : WARNING: [gps] could not get GPS time from GPS :: 3064
Aug 5 20:13:12 nbl_ec2x local5.info lora_pkt_fwd: [I] src/lora_pkt_fwd.c : WARNING: [gps] could not get GPS time from GPS :: 3064
Aug 5 20:13:12 nbl_ec2x local5.info lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: Received pkt from mote: 01010101 (fcnt=257) :: 1885
Aug 5 20:13:12 nbl_ec2x local5.info lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up:
{"rxpk":[{"tmst":21445692,"time":"2021-08-05T14:43:12.000000Z","chan":2,"rfch":1,"freq":865.985000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":6.5,"rssi":-59,"size":23
Aug 5 20:13:13 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : WARNING: [gps] could not get GPS time from GPS :: 3064
Aug 5 20:13:14 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: Received pkt from mote: 01010101 (fcnt=257) :: 1885
Aug 5 20:13:14 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":23299716,"time":"2021-08-05T14:43:14.000000Z","chan":1,"rfch":0,"freq":865.402500,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","lsnr":-9.2,"rssi":-109,"size":
Aug 5 20:13:14 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":23317300,"time":"2021-08-05T14:43:14.000000Z","chan":2,"rfch":1,"freq":865.985000,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","lsnr":-10.8,"rssi":-111,"size"
Aug 5 20:13:14 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":23467884,"time":"2021-08-05T14:43:14.000000Z","chan":0,"rfch":0,"freq":865.062500,"stat":1,"modu":"LORA","datr":"SF11BW125","codr":"4/5","lsnr":-6.8,"rssi":-109,"size":
Aug 5 20:13:16 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: [down] received out-of-sync ACK :: 2617
Aug 5 20:13:16 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: [down] PULL_ACK received in 3242 ms :: 2614
Aug 5 20:13:17 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: Received pkt from mote: 00000000 (fcnt=0) :: 1885
Aug 5 20:13:17 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":26125452,"time":"2021-08-05T14:43:17.000000Z","chan":0,"rfch":0,"freq":865.062500,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":3.2,"rssi":-97,"size":23
Aug 5 20:13:17 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: [down] PULL_RESP received - token[51:219] :) :: 2624
Aug 5 20:13:17 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON down: {"txpk":{"imme":false,"rfch":0,"powe":27,"ant":0,"brd":0,"tmst":8256724,"freq":865.4025,"modu":"LORA","datr":"SF10BW125","codr":"4/5","ipol":true,"size":17,"data":"IJswvADTOiS1ZT8juJ7
Aug 5 20:13:17 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : ERROR: Packet REJECTED (jit error=2) :: 2932
Aug 5 20:13:17 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON down: {"txpk":{"imme":false,"rfch":0,"powe":27,"ant":0,"brd":0,"tmst":9256724,"freq":866.55,"modu":"LORA","datr":"SF10BW125","codr":"4/5","ipol":true,"size":17,"data":"IJswvADTOiS1ZT8juJ77S
Aug 5 20:13:17 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: Received pkt from mote: 01010101 (fcnt=257) :: 1885
Aug 5 20:13:17 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":26538884,"time":"2021-08-05T14:43:17.000000Z","chan":2,"rfch":1,"freq":865.985000,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","lsnr":-7.0,"rssi":-109,"size":
Aug 5 20:13:18 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: Received pkt from mote: 01010101 (fcnt=257) :: 1885
Aug 5 20:13:18 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":27674676,"time":"2021-08-05T14:43:18.000000Z","chan":1,"rfch":0,"freq":865.402500,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","lsnr":-4.0,"rssi":-108,"size":
Aug 5 20:13:20 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: Received pkt from mote: 01010101 (fcnt=257) :: 1885
Aug 5 20:13:20 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":29450724,"time":"2021-08-05T14:43:20.000000Z","chan":0,"rfch":0,"freq":865.062500,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","lsnr":-16.5,"rssi":-109,"size"
Aug 5 20:13:20 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":29918612,"time":"2021-08-05T14:43:20.000000Z","chan":2,"rfch":1,"freq":865.985000,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","lsnr":6.0,"rssi":-44,"size":23
Aug 5 20:13:20 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":30114804,"time":"2021-08-05T14:43:20.000000Z","chan":2,"rfch":1,"freq":865.985000,"stat":1,"modu":"LORA","datr":"SF11BW125","codr":"4/5","lsnr":1.5,"rssi":-42,"size":23
Aug 5 20:13:22 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: Received pkt from mote: 01010101 (fcnt=257) :: 1885
Aug 5 20:13:22 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":31413340,"time":"2021-08-05T14:43:22.000000Z","chan":0,"rfch":0,"freq":865.062500,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":10.0,"rssi":-25,"size":2
Aug 5 20:13:22 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":31449628,"time":"2021-08-05T14:43:22.000000Z","chan":1,"rfch":0,"freq":865.402500,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":8.5,"rssi":-39,"size":23
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : ##### 2021-08-05 14:43:23 GMT ##### :: 1606
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : ### [UPSTREAM] ### :: 1607
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # RF packets received by concentrator: 68 :: 1608
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # CRC_OK: 61.76%, CRC_FAIL: 38.24%, NO_CRC: 0.00% :: 1609
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # RF packets forwarded: 42 (959 bytes) :: 1610
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # PUSH_DATA datagrams sent: 1 (244 bytes) :: 1611
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # PUSH_DATA acknowledged: 0.00% :: 1612
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : ### [DOWNSTREAM] ### :: 1613
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # PULL_DATA sent: 3 (33.33% acknowledged) :: 1614
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # PULL_RESP(onse) datagrams received: 2 (388 bytes) :: 1615
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # RF packets sent to concentrator: 0 (34 bytes) :: 1616
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # TX errors: 0 :: 1617
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # TX rejected (collision packet): 0.00% (req:2, rej:0) :: 1619
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # TX rejected (collision beacon): 0.00% (req:2, rej:0) :: 1620
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # TX rejected (too late): 0.00% (req:2, rej:0) :: 1621
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # TX rejected (too early): 100.00% (req:2, rej:2) :: 1622
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # BEACON queued: 0 :: 1624
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # BEACON sent so far: 0 :: 1625
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # BEACON rejected: 0 :: 1626
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : ### [JIT] ### :: 1627
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # SX1301 time (PPS): 2514842 :: 1635
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : ### [GPS] ### :: 1638
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # Invalid time reference (age: 1628174603 sec) :: 1644
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : # no valid GPS coordinates available yet :: 1649
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : ##### END ##### :: 1656
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"stat":{"time":"2021-08-05 14:43:23 GMT","rxnb":68,"rxok":42,"rxfw":42,"ackr":0.0,"dwnb":2,"txnb":0,"metadata":"OtherProperties=,rebooted=1"}} :: 2191
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: [up] PUSH_ACK received in 8 ms :: 2260
Aug 5 20:13:23 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: [down] PULL_ACK received in 0 ms :: 2614
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : WARNING: [gps] could not get GPS time from GPS :: 3064
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: Received pkt from mote: 01010101 (fcnt=257) :: 1885
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":33338804,"time":"2021-08-05T14:43:24.000000Z","chan":1,"rfch":0,"freq":865.402500,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","lsnr":-12.0,"rssi":-111,"size"
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: [up] PUSH_ACK received in 0 ms :: 3679
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: Internet connected :: 3684
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":33489420,"time":"2021-08-05T14:43:24.000000Z","chan":0,"rfch":0,"freq":865.062500,"stat":1,"modu":"LORA","datr":"SF11BW125","codr":"4/5","lsnr":-7.2,"rssi":-108,"size":
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON up: {"rxpk":[{"tmst":33548172,"time":"2021-08-05T14:43:24.000000Z","chan":1,"rfch":0,"freq":865.402500,"stat":1,"modu":"LORA","datr":"SF11BW125","codr":"4/5","lsnr":-6.0,"rssi":-109,"size":
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: [down] PULL_RESP received - token[189:0] :) :: 2624
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON down: {"txpk":{"imme":false,"rfch":0,"powe":27,"ant":0,"brd":0,"tmst":38338804,"freq":865.4025,"modu":"LORA","datr":"SF10BW125","codr":"4/5","ipol":true,"size":17,"data":"IJOVy1Y3oZ/ADcAo3D
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: [down] PULL_RESP received - token[106:254] :) :: 2624
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON down: {"txpk":{"imme":false,"rfch":0,"powe":27,"ant":0,"brd":0,"tmst":38548172,"freq":865.4025,"modu":"LORA","datr":"SF11BW125","codr":"4/5","ipol":true,"size":17,"data":"IFCvB//dhvyRJZfcCL
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : ERROR: Packet REJECTED (jit error=5) :: 2932
Aug 5 20:13:24 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : JSON down: {"txpk":{"imme":false,"rfch":0,"powe":27,"ant":0,"brd":0,"tmst":39548172,"freq":866.55,"modu":"LORA","datr":"SF10BW125","codr":"4/5","ipol":true,"size":17,"data":"IFCvB//dhvyRJZfcCLal
Aug 5 20:13:25 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : WARNING: [gps] could not get GPS time from GPS :: 3064
Aug 5 20:13:25 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : INFO: Received pkt from mote: 00000000 (fcnt=0) :: 1885
Aug 5 20:13:15 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : WARNING: [gps] could not get GPS time from GPS :: 3064
Aug 5 20:13:16 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : WARNING: [gps] could not get GPS time from GPS :: 3064
Aug 5 20:13:17 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : WARNING: [gps] could not get GPS time from GPS :: 3064
Aug 5 20:13:19 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : WARNING: [gps] could not get GPS time from GPS :: 3064
Aug 5 20:13:20 lora_pkt_fwd: [I] src/lora_pkt_fwd.c : WARNING: [gps] could not get GPS time from GPS :: 3064
Gateway: we are using our Gateway
Device: only 10-15 devices are joined out of 300+ (All the devices are sending JoinRequests)
Thanks
