##### 2022-08-16 06:20:25 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 1
# CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
# RF packets forwarded: 1 (23 bytes)
# PUSH_DATA datagrams sent: 2 (319 bytes)
# PUSH_DATA acknowledged: 100.00%
### [DOWNSTREAM] ###
# PULL_DATA sent: 3 (100.00% acknowledged)
# PULL_RESP(onse) datagrams received: 0 (0 bytes)
# RF packets sent to concentrator: 0 (0 bytes)
# TX errors: 0
# BEACON queued: 0
# BEACON sent so far: 0
# BEACON rejected: 0
### [JIT] ###
src/jitqueue.c:511:jit_print_queue(): INFO: [jit] queue is empty
### [GPS] ###
# Invalid time reference (age: 1660630825 sec)
# no valid GPS coordinates available yet
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:20:25 GMT","rxnb":1,"rxok":1,"rxfw":1,"a ckr":100.0,"dwnb":0,"txnb":0}}
INFO: [up] PUSH_ACK received in 0 ms
INFO: Received pkt from mote: FE0037B5 (fcnt=7945)
JSON up: {"rxpk":[{"tmst":1043737964,"chan":1,"rfch":1,"freq":868.300000,"stat": 1,"modu":"LORA","datr":"SF8BW125","codr":"4/5","lsnr":10.5,"rssi":-91,"size":23, "data":"ALU3AP7/CR+stTcA/v8JH6y03lEYsOw="}]}
INFO: [down] PULL_ACK received in 0 ms
JSON up: {"rxpk":[{"tmst":1050878364,"chan":1,"rfch":1,"freq":868.300000,"stat": 1,"modu":"LORA","datr":"SF9BW125","codr":"4/5","lsnr":13.0,"rssi":-91,"size":23, "data":"ALU3AP7/CR+stTcA/v8JH6wAF9cpgoM="}]}
INFO: [up] PUSH_ACK received in 1 ms
JSON up: {"rxpk":[{"tmst":1058087420,"chan":1,"rfch":1,"freq":868.300000,"stat": 1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","lsnr":8.0,"rssi":-94,"size":23, "data":"ALU3AP7/CR+stTcA/v8JH6wEpm+Lpog="}]}
INFO: Disabling GPS mode for concentrator's counter...
INFO: host/sx1301 time offset=(1660629782s:765797µs) - drift=-9µs
INFO: Enabling GPS mode for concentrator's counter.
##### 2022-08-16 06:20:55 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 3
# RF packets forwarded: 3 (69 bytes)
# PUSH_DATA datagrams sent: 4 (734 bytes)
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660630855 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:20:55 GMT","rxnb":3,"rxok":3,"rxfw":3,"a ckr":100.0,"dwnb":0,"txnb":0}}
JSON up: {"rxpk":[{"tmst":1074292652,"chan":0,"rfch":1,"freq":868.100000,"stat": 1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":7.8,"rssi":-103,"size":23 ,"data":"ALU3AP7/CR+stTcA/v8JH6x1aw6+fyE="}]}
##### 2022-08-16 06:21:25 GMT #####
### [UPSTREAM] ###
# PUSH_DATA datagrams sent: 2 (321 bytes)
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660630885 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:21:25 GMT","rxnb":1,"rxok":1,"rxfw":1,"a ckr":100.0,"dwnb":0,"txnb":0}}
INFO: Received pkt from mote: 000005D6 (fcnt=31232)
JSON up: {"rxpk":[{"tmst":1104217164,"chan":1,"rfch":1,"freq":868.300000,"stat": 1,"modu":"LORA","datr":"SF8BW125","codr":"4/5","lsnr":11.5,"rssi":-99,"size":23, "data":"ANYFAAAAAHq+0DcA/v8JH6wGP+/RuMI="}]}
INFO: host/sx1301 time offset=(1660629782s:765789µs) - drift=-8µs
##### 2022-08-16 06:21:55 GMT #####
### [UPSTREAM] ###
# PUSH_DATA datagrams sent: 2 (320 bytes)
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660630915 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:21:55 GMT","rxnb":1,"rxok":1,"rxfw":1,"a ckr":100.0,"dwnb":0,"txnb":0}}
JSON up: {"rxpk":[{"tmst":1134772988,"chan":0,"rfch":1,"freq":868.100000,"stat": 1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":10.8,"rssi":-99,"size":23 ,"data":"ANYFAAAAAHq+0DcA/v8JH6y3FL3UJcg="}]}
##### 2022-08-16 06:22:25 GMT #####
### [UPSTREAM] ###
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660630945 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:22:25 GMT","rxnb":1,"rxok":1,"rxfw":1,"a ckr":100.0,"dwnb":0,"txnb":0}}
INFO: host/sx1301 time offset=(1660629782s:765779µs) - drift=-10µs
##### 2022-08-16 06:22:55 GMT #####
### [UPSTREAM] ###
# CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
# RF packets forwarded: 0 (0 bytes)
# PUSH_DATA datagrams sent: 1 (113 bytes)
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660630975 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:22:55 GMT","rxnb":1,"rxok":0,"rxfw":0,"a ckr":100.0,"dwnb":0,"txnb":0}}
##### 2022-08-16 06:23:25 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 0
# CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660631005 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:23:25 GMT","rxnb":0,"rxok":0,"rxfw":0,"a ckr":100.0,"dwnb":0,"txnb":0}}
INFO: host/sx1301 time offset=(1660629782s:765767µs) - drift=-12µs
##### 2022-08-16 06:23:55 GMT #####
### [UPSTREAM] ###
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660631035 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:23:55 GMT","rxnb":0,"rxok":0,"rxfw":0,"a ckr":100.0,"dwnb":0,"txnb":0}}
##### 2022-08-16 06:24:25 GMT #####
### [UPSTREAM] ###
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660631065 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:24:25 GMT","rxnb":0,"rxok":0,"rxfw":0,"a ckr":100.0,"dwnb":0,"txnb":0}}
INFO: host/sx1301 time offset=(1660629782s:765752µs) - drift=-15µs
##### 2022-08-16 06:24:55 GMT #####
### [UPSTREAM] ###
# PULL_DATA sent: 2 (100.00% acknowledged)
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660631095 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:24:55 GMT","rxnb":1,"rxok":0,"rxfw":0,"a ckr":100.0,"dwnb":0,"txnb":0}}
##### 2022-08-16 06:25:25 GMT #####
### [UPSTREAM] ###
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660631125 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:25:25 GMT","rxnb":0,"rxok":0,"rxfw":0,"a ckr":100.0,"dwnb":0,"txnb":0}}
INFO: host/sx1301 time offset=(1660629782s:765740µs) - drift=-12µs
##### 2022-08-16 06:25:55 GMT #####
### [UPSTREAM] ###
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660631155 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:25:55 GMT","rxnb":0,"rxok":0,"rxfw":0,"a ckr":100.0,"dwnb":0,"txnb":0}}
##### 2022-08-16 06:26:25 GMT #####
### [UPSTREAM] ###
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660631185 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:26:25 GMT","rxnb":0,"rxok":0,"rxfw":0,"a ckr":100.0,"dwnb":0,"txnb":0}}
INFO: host/sx1301 time offset=(1660629782s:765726µs) - drift=-14µs
##### 2022-08-16 06:26:55 GMT #####
### [UPSTREAM] ###
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660631215 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:26:55 GMT","rxnb":1,"rxok":0,"rxfw":0,"a ckr":100.0,"dwnb":0,"txnb":0}}
JSON up: {"rxpk":[{"tmst":1442946059,"chan":0,"rfch":1,"freq":868.100000,"stat": 1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":9.8,"rssi":-99,"size":23," data":"ANYFAAAAAHq+0DcA/v8JH6zsqZbiB2k="}]}
JSON up: {"rxpk":[{"tmst":1450045884,"chan":2,"rfch":1,"freq":868.500000,"stat": 1,"modu":"LORA","datr":"SF8BW125","codr":"4/5","lsnr":8.0,"rssi":-99,"size":23," data":"ANYFAAAAAHq+0DcA/v8JH6ywx+NBJHs="}]}
##### 2022-08-16 06:27:25 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 2
# RF packets forwarded: 2 (46 bytes)
# PUSH_DATA datagrams sent: 3 (525 bytes)
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
# Invalid time reference (age: 1660631245 sec)
##### END #####
JSON up: {"stat":{"time":"2022-08-16 06:27:25 GMT","rxnb":2,"rxok":2,"rxfw":2,"a ckr":100.0,"dwnb":0,"txnb":0}}
JSON up: {"rxpk":[{"tmst":1480598172,"chan":2,"rfch":1,"freq":868.500000,"stat": 1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":9.0,"rssi":-96,"size":23, "data":"ANYFAAAAAHq+0DcA/v8JH6yNFZGf8Y0="}]}
Hi may i know wether the packet forwarder actually able to receive and sent data or not i dont know how to read this log.
