Hi All,
I am new to Lora Protocol and I am using SX1302 concentrator while receiving Uplink packet ACK from server to EndNode, After receiving ACK in Node side I am getting below error in Gateway.
Gateway:
INFO: Received pkt from mote: 004D84E0 (fcnt=0)
JSON up: {“rxpk”:[{“jver”:1,“tmst”:6851846,“chan”:0,“rfch”:0,“freq”:865.062500,“mid”: 0,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”}
JSON up: :“SF12BW125”,“codr”:“4/5”,“rssis”:-68,“lsnr”:8.5,“foff”:-14824,“rssi”:-68,“size”:18,“data”:“gOCETQAAAACk2qGKwsl37PT+”}]}
INFO: [up] PUSH_ACK received in 1 ms
INFO: [down] PULL_RESP received - token[158:174]
JSON down: {“txpk”:{“imme”:false,“tmst”:11851846,“freq”:865.0625,“rfch”:0,“powe”:27,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“ipol”:true,}
INFO: [down] PULL_ACK received in 0 ms
ERROR: Parity error check failed on AGC firmware
ERROR: [up] failed packet fetch, exiting
EndNode :
AT+SEND=1700: HELLO
OK
txDone
rxTimeOut
txDone
rxTimeOut
txDone
rxDone
