Payload decoder Javascript
Hello everyone,
I receive some data from my sensor :
This is the payload that I’m expected, but when I’m checking in “Event” at data it shows me this :
Which for me is an issue because when I put some java to decode the payload I get something like this :
My goal is to send those data to InfluxDB, so first I need to decode this payload image, but I can’t If I’m not able to retrieve the data into a variable.
Thank you very much!
Sounds like you’re decoding it wrong. The data field in the uplink is shown in Base64 encoding, you’ll want to do a base64 to hex conversion.
If you paste your data into here: https://cryptii.com/pipes/base64-to-hex you get your expected bytes in hex.
Hi Ritch, It sounds to me that you are missing one conversion.
You should receive data in base64, transform it to hex and, finally, from hex to ascii.
I needed to do this conversion to use THINGSBOARD http integration (so that Thingsboard can “read” the data properly).
PS: You should also “split” or “parse” the data in the correct bytes.
I have some guides here.
You need to convert from hex/base64 to json or human readable ascii
I find the issue of my problem, yes.
function decodeUplink(input)
  return{
    data: Decode(input.fPort, input.bytes, input.variables)
function Decode(fPort, bytes, variables) {
  var data ={"Temp1":"",
             "Temp2":"",
             "battery":"",
             "bytes":""};
  data.battery= bytes[1] & 0x0002;
  data.Temp1= (bytes[3] + bytes[2])/10;
  data.Temp2= (bytes[5] + bytes[4])/10;
  data.bytes= bytes;
  return data;
This is the code that I used to decode the payload of an Adeunis Temp sensor :slight_smile:
Thanks for sharing!
May be useful for someone
