Good day y’all!
I am experiencing difficulty with accessing my Network Config file, and so my gateway is not connecting to the ChirpStack server created.
When I try to access it, it says access denied.
/etc/chirpstack-network-server/chirpstack-network-server configfile > chirpstack-network-se rver.toml
Any and all help is APPRECIATED
I think it has something to do with this problem"
When I enter:
journalctl -u chirpstack-gateway-bridge -f -n 50
It has problems connecting, then it is connected as seen below:
Nov 19 00:14:04 ip-172-31-41-91 chirpstack-gateway-bridge[17796]: time=“2020-11-19T00:14:04Z” level=info msg=“backend/semtechudp: starting gateway udp listener” addr=“0.0.0.0:1700”
Nov 19 00:14:04 ip-172-31-41-91 chirpstack-gateway-bridge[17796]: time=“2020-11-19T00:14:04Z” level=info msg=“integration/mqtt: connected to mqtt broker”
Nov 20 00:30:48 ip-172-31-41-91 systemd[1]: Stopping ChirpStack Gateway Bridge…***
Nov 20 00:30:48 ip-172-31-41-91 chirpstack-gateway-bridge[17796]: time=“2020-11-20T00:30:48Z” level=info msg=“signal received” signal=terminated
Nov 20 00:30:48 ip-172-31-41-91 chirpstack-gateway-bridge[17796]: time=“2020-11-20T00:30:48Z” level=warning msg=“shutting down server”
Nov 20 00:30:48 ip-172-31-41-91 systemd[1]: Stopped ChirpStack Gateway Bridge.
Nov 20 00:30:48 ip-172-31-41-91 systemd[1]: Started ChirpStack Gateway Bridge.
Nov 20 00:30:48 ip-172-31-41-91 chirpstack-gateway-bridge[15781]: time=“2020-11-20T00:30:48Z” level=info msg=“starting ChirpStack Gateway Bridge” docs=“https://www.chirpstack.io/gateway-bridge/” version=3.9.2
Nov 20 00:30:48 ip-172-31-41-91 chirpstack-gateway-bridge[15781]: time=“2020-11-20T00:30:48Z” level=info msg=“backend/semtechudp: starting gateway udp listener” addr=“0.0.0.0:1700”
Nov 20 00:30:48 ip-172-31-41-91 chirpstack-gateway-bridge[15781]: time=“2020-11-20T00:30:48Z” level=info msg=“integration/mqtt: connected to mqtt broker”
My main problem could be I have the wrong config file (.toml), do you think that is the problem?
